ESC for 1527 1D
  • bedrock
    • Aug 2009
    • 248
    ESC for 1527 1D
    Hi all
    Just invested in 2 1527 1D motors - I plan to run them in a 1.3mtr hull.....
    Any suggestions to good ESC'S for this plan to run 2 X442's
    I am currently putting one of these into a 38inch rigger and running a CC LV 240... with cap board... prop Prather 220...
    I am thinking Etti HV 200 ????
    thanks in advance
    Bedrock
    ________
    MEDICAL MARIJUANA GROW
  • Flying Scotsman
    Fast Electric Adict!
    • Jun 2007
    • 5190
    What voltage/hull/etc.? That is a large hull length!
    Douggie
    • bedrock
      • Aug 2009
      • 248
      Douggie
      Looking at the Drambuie on ice - length 1300mm approx
      Looking at 1527 1D Twin - Hyperion 45C 6S 2P props X442
      Let me know what you guys think.. - should be fast......
      Bedrock
      ________
      THE TOYOTA WAY HISTORY
      • Flying Scotsman
        • Jun 2007
        • 5190
        Twin power is very neat but expensive and no speed advantage IMO. I trust that some lads with knowledge of twin setups will chime in on a hull of that size
        Douggie
          What use? The 1527/1D is a SAW motor only on 6S with rpm in the 45,000 range. I ran an 875mm cat into the 80s through the traps with it, but the amp draw was very high. A 150 amp controller will not be enough and run time will be short due to heat buildup. a 1527/1.5D is much more appropriate.
          • RaceMechaniX
            • Sep 2007
            • 2821
            Agree with Fluid, a 1D is a SAW or 2 lap motor unless carefully set-up. If you do use them, I would suggest at least a 200A+ controller. You could try the Etti 200A HV, Swordfish HV, CC 240HV or a 32.200 Schulze.
            A 442 shuold be a safe starting point.
            Tyler
            Tyler Garrard
            NAMBA 639/IMPBA 20525
            T-Hydro @ 142.94mph former WR
            • MarkF
              dinogylipos.com
              • Mar 2008
              • 979
              That motor would also be good on 4s. You can run a 447 to 450 prop and still have decent speed. Stick with the 200 amp controllers.
              Mark
              • Rumdog
                • 6453
                also,442's are not going to push a 54 in cat well at all. They also will no load the motors, so they will get very hot, even on 4s. I'd run 4s2p per motor on at least 50mm props.
