What wood to use?
  • Boatman
    • Jan 2008
    • 796
    What wood to use?
    I need to set my motors at an angle and was thinking wood would work but what kind. I have used a piece of pine 2x4 for a servo once but with mixed feelings. Hull is carbon, motor mount is metal. What type of wood will take to epoxy and work for a wedge? This is a flat piece about 3x4 inches at about 20 degree angle.
  • blackcat26
    High Speed Junkie
    • Sep 2009
    • 1598
    Why not lay a set up from carbon? Seems a shame to put wood in it.
    • sailr
      • Nov 2007
      • 6927
      For strength, use OAK! It also won't soak up water as bad as soft woods like pine, basswood, ash, etc.
      Mini Cat Racing USA
      www.minicatracingusa.com
      • steveo
        • 1454
        as long as you coat the wood with epoxy you can use any type
        • tth
          • Apr 2008
          • 1510
          I hope you're not going to put wood in that HPR!!! At least cover the wood with some carbon, or paint black? If you absolutely need to use wood do it with oak for those big motors.
          • Boatman
            • Jan 2008
            • 796
            Maybe I should snap a couple photos for reference. The wedge will be completely surrounded with epoxy and on top of that will have a few layers of glass with the epoxy. It's the last step and I will use whatever is available. Carbon is not. black paint is.
            • tth
              • Apr 2008
              • 1510
              Shoot me a PM with your addy I have a little scrap CF laying around. Also the dimensions would help.
              • Boatman
                • Jan 2008
                • 796
                thanks but email was sent back. Here are a few pics. If you see the mounts are made to come apart easy for whatever and they also fit a couple diff. size motors. The solid plate is milled out on the bottom for epoxy and glass to lay in. I just need them tilted a bit as you will see with the dominos.
                • Boatman
                  • Jan 2008
                  • 796
                  Don't tear it apart quite yet. I am no where near complete. Just basic structure.
                  • BakedMopar
                    No Mo Slipah
                    • Sep 2009
                    • 1679
                    Here's a thought. Why not use a peice of aluminum to prop up the front?
                    • bonewar
                      • Jan 2008
                      • 549
                      Dude,
                      Make the wedge out of hardwood.
                      And i will send you a piece of black carbon fiber plate 1mm thick, enough to cover it.
                      Perfect strong and pretty.
                      Bonewar
                      SIMRAD MARITIMO TWIN 1512 NEU'S , M12 MARITIMO SINGLE 1527 NEU , SV27 1509 NEU , SV27 NITRO O.S. 18CV-R 3.0cc WATER COOLED RACE ENGINE.
                      • bonewar
                        • Jan 2008
                        • 549
                        Originally posted by bonewar
                        Dude,
                        Bonewar
                        Better yet !!
                        Measure your servo set up and the wedges and i will make you a very shinny 1mm
                        thick black carbon fiber plate out of the spare stuff i have lying around.
                        Enough to do the job.
                        You pay the postage.
                        Bonewar
                        • sailr
                          • Nov 2007
                          • 6927
                          Did Peter make those mounts for you? Why not have him machine the wedges too?
                          Mini Cat Racing USA
