I need to set my motors at an angle and was thinking wood would work but what kind. I have used a piece of pine 2x4 for a servo once but with mixed feelings. Hull is carbon, motor mount is metal. What type of wood will take to epoxy and work for a wedge? This is a flat piece about 3x4 inches at about 20 degree angle.
What wood to use?
Why not lay a set up from carbon? Seems a shame to put wood in it.FE BOATING: Less like a hobby and more like an addiction! -
For strength, use OAK! It also won't soak up water as bad as soft woods like pine, basswood, ash, etc.Mini Cat Racing USA
I hope you're not going to put wood in that HPR!!! At least cover the wood with some carbon, or paint black? If you absolutely need to use wood do it with oak for those big motors.* BBY Lift Master RIgger * Insane Gen 2 Cat * Aeromarine Avenger Pro Twin * Delta Force Cyber Storm * Delta Force 41" Mono * H&M Viper II * H&M Intruder * OSE Raider Hydro * Whiplash 20 * Brushless Mini Rio *Comment
Maybe I should snap a couple photos for reference. The wedge will be completely surrounded with epoxy and on top of that will have a few layers of glass with the epoxy. It's the last step and I will use whatever is available. Carbon is not. black paint is.Comment
Shoot me a PM with your addy I have a little scrap CF laying around. Also the dimensions would help.* BBY Lift Master RIgger * Insane Gen 2 Cat * Aeromarine Avenger Pro Twin * Delta Force Cyber Storm * Delta Force 41" Mono * H&M Viper II * H&M Intruder * OSE Raider Hydro * Whiplash 20 * Brushless Mini Rio *Comment
thanks but email was sent back. Here are a few pics. If you see the mounts are made to come apart easy for whatever and they also fit a couple diff. size motors. The solid plate is milled out on the bottom for epoxy and glass to lay in. I just need them tilted a bit as you will see with the dominos.Comment
Here's a thought. Why not use a peice of aluminum to prop up the front?If all of your wishes are granted, many of your dreams will be destroyed!Comment
Dude,
Make the wedge out of hardwood.
And i will send you a piece of black carbon fiber plate 1mm thick, enough to cover it.
Perfect strong and pretty.
BonewarSIMRAD MARITIMO TWIN 1512 NEU'S , M12 MARITIMO SINGLE 1527 NEU , SV27 1509 NEU , SV27 NITRO O.S. 18CV-R 3.0cc WATER COOLED RACE ENGINE.Comment
Measure your servo set up and the wedges and i will make you a very shinny 1mm
thick black carbon fiber plate out of the spare stuff i have lying around.
Enough to do the job.
You pay the postage.
Did Peter make those mounts for you? Why not have him machine the wedges too?
thanks but email was sent back. Here are a few pics. If you see the mounts are made to come apart easy for whatever and they also fit a couple diff. size motors. The solid plate is milled out on the bottom for epoxy and glass to lay in. I just need them tilted a bit as you will see with the dominos.Mini Cat Racing USA
