Better KV for a Neu
  • vasy
    • Dec 2009
    • 333
    Better KV for a Neu
    What is the best option for Neu running in 1 meeter cat with x642 prop on 6s lipo.
    1521/1.5D 1860Kv or 1521/1Y 1577Kv?
    The 1.5D is a 4S motor, not a 6S motor. The 1Y is a better choice, but an x642 is a little small for a 40" cat. Depending on the use, a better choice may be a 1527/1Y running an x450 to x455 prop. Speeds around 60 mph with the x455...
    • vasy
      • Dec 2009
      • 333
      Ya, I though 1.5D was a little too hot, maybe 5s max yeh?
      No stock for a 1527, it sounds like a better motor for the hull but might have to stick with what is in stock. Do you think 1527/1Y will take a better prop for the boat?
      (Genesis is the hull)
      • westbeach
        OSE Rocks!
        • 951
        Igor,
        The 1527-1Y you can run 6S giving you an approx 27,750KV/RPM Which means you can prop up as Jay had suggested.
        HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
        • westbeach
          OSE Rocks!
          • 951
          Try Jim W at Southriver rc, he stocks Neu motor too. He might have what you need in stock seeing Steve has none in stock at the moment.
          Originally posted by vasy
          No stock for a 1527, it sounds like a better motor for the hull but might have to stick with what is in stock. (Genesis is the hull)
          • vasy
            • Dec 2009
            • 333
            Same as Southriver rc, he only has 8mm version. I see 1527 is a HUGE motor.
            I wonder if it even fin under the hatch. there is not that much clearance in this hull.
              Vasy, the 1527 motor is only 10mm longer than the 1521, all other dimensions are the same. I prefer the 8mm version, you can get a flex hex from 8mm to 0.187" at OSE. You will need the 0.187" cable for this application.
              • vasy
                • Dec 2009
                • 333
                It is not 10 but rather 18mm longer. I'll have to measure the inside.
                Will look into making a new flex as that will require changing the stuffing tube.
