Delta Force 33 need HELP
  • nova68
    • Jul 2008
    • 151
    I have a Delta Force 33 which I have a NEU 1515/1Y. I am thinking of a CC Hydra 240 LV on 4S2P Lipos is the Hydra 240 an over kill or is it OK. I am not sure want prop to use,maybe Octura X 442 I need a little help on the ESC and Prop size PLEASE.
  • sailr
    • Nov 2007
    • 6927
    Good choice although a Seaking 180 will work fine. The 1515/1Y is very efficient and doesn't suck the amps like some other motors. Big difference in price too. It is what I am using in my DF33 P Mono with the same motor. I'm running a detongued 642 on my boat as I recall.
    Mini Cat Racing USA
    www.minicatracingusa.com
    • highndry
      • Nov 2007
      • 664
      try a 447...good set-up
      Boats don't win races, drivers do.
      • Rumdog
        • 6453
        A447 will pull a lot of amps! A m445 worked well for me.
        • sailr
          • Nov 2007
          • 6927
          Hey HighNDry....thanks. I AM running a 447, not a 642! Amps are good.
          Mini Cat Racing USA
          • RaceMechaniX
            • Sep 2007
            • 2833
            It all depends on how much prop you want to hang off the back and how heavy the boat is. Your safest best is the 240LV, but is you prop reasonably a 120LV or a Turnigy 180A will probably work fine.
            Tyler Garrard
            NAMBA 639/IMPBA 20525
            T-Hydro @ 142.94mph former WR
            • BHChieftain
              Fast Electric Addict
              • 1969
              I'm running a neu 1515 1.5y on 4S1P, using hydra 240A ESC (not LV or HV). Got all the way up to an x648 prop and motor/esc are cool as a cucumber...
              Chief
              • tth
                • Apr 2008
                • 1510
                Chief
                LV=Low Voltage
                HV=High Voltage
                You have to have one of the two, its all they offer.
                • BHChieftain
                  • 1969
                  I must have the "LV" version, then.
                  Thanks,
                  Chief
                  • BakedMopar
                    No Mo Slipah
                    • Sep 2009
                    • 1679
                    Chief
                    He's running a 1515 1y which is 2200kv and you running a 1515 1.5y which is 1500kv. These two motors have a very different amp draw.
                    • nova68
                      • Jul 2008
                      • 151
                      Df 33
                      I want to thank all of you and I appreciate all of your input I think I will run the CC Hydra 240 LV with Octura X 442 or X 445. THANKS
