hobbyking v hull:pursuit
  • vasy
    • Dec 2009
    • 333
    Originally posted by dgfarb
    If oyu remove the stinger, the short shaft slides out easily. It woun't fit through the stuffing tube, so it stops there when stinger is installed.
    Not happening for me... they stuffed it so hard into the motor coupling it is not budging one bit.
    • dgfarb
      • Apr 2010
      • 57
      I was refering to the short rigid portion in the stinger. If you pull the stinger off, it will stay with it. Mine was bent, so I had to straighten it first. Then tap it from the end sticking out, and it will come right out. As for the collet being tight into the coupler, that will take some work. I ordered a flex shaft, and will be tackling getting the stock one out of the collet this weekend. Even though the specs say 4 mm, it actually measures .180, so a 3/16" should work.
      If you search member electric And Delta Force in advance search, you'll find more info.
      • questtek
        • May 2009
        • 556
        Originally posted by mschaffer66
        Does anyone have feedback about this boat? Is it a decent Hull?
        Looks good and the Genesis got good reviews...
        See post #49 in this forum link:
        http://forums.offshoreelectrics.com/...pursuit&page=2
