Motor timing ??
  • Brushless01
    • Apr 2010
    • 487
    Motor timing ??
    Hi everybody what should the motor timing be on a feigao 540 9xl ??
    Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.
    What model will it be in? How many volts will you be using? What amp draw? Racing or sport running? What controller? How long will you be running each time you drop the boat in the water?
    All the above will effect what the timing advance should be. Run between 5 and 15 degrees advance depending on the use.
    • Brushless01
      • Apr 2010
      • 487
      Geneesis catamaran seaking 180 6s lipo
        The timing really won't matter then, that is too much voltage for a 9XL for anything but SAW running. You'll be buying a new ESC soon unless you are conservative on props and limit your run time to one minute or less - check temperatures often. Use around 7-10 degrees.
        • properchopper
          • 6968
          With that setup have fire extinguisher and air freshener close by
          • Brushless01
            • Apr 2010
            • 487
            Ow ok how about a 10xl on a 45mm prop
            • Salty
              • Jul 2008
              • 30
              WOW I didn't realize all of those elements effect timing!!!
              So what should I set my 540L 2666KV up at?
              It is running on 3S in a 35" mono with a X431 prop through a Tactic and a Barracuda 80.
              Just sport running.....
