Hi guys im going to shortly get a aquacraft miss vegas deuce and convert it to fe. Im going to get either a seaking 180 or hydra 240. Im going to run a 6s pack but need to know what motor a 8xl or 10xl. Also any prop ideas ??
8XL OR 10XL on 6S
8XL OR 10XL on 6S
Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.Tags: None -
I wanna see speeds around 60mph will it do it in the 10xl and any ideas on a propPrince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.Comment
it's a pretty big boat for a Feigao XL!!! you'd better go for a NEU if you want to reach 60mph! maybe a 580 can do it but a 540XL won't last!Comment
6S packs might not fit, its pretty tight in there.Grand River Marine Modellers
Neither. If you are looking for a true 60mph, I agree with the other guys. The 540xl is not large enough to push it to 60. You will need a Neu.Steven Vaccaro
A 1515 1.5Y may get you there.........if not a 1521 1Y should.................6s of courseLast edited by Make-a-Wake; 06-03-2010, 09:32 PM.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
Ivs seen vids on youtube by several people and they flyPrince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.Comment
I was about to post the same link Doby
It would certainly fly, once averything on board had turn to smokeComment
I run a 1515 1Y on 4S2P in my Vegas [ not the Deuce]. It clocks a consistant 60 + mph every run, and I've had the boat almost a year. The boat is the 2009-2010 NAMBA P-Sport Hydro 2-Lap record holder as well. It comes in cool on the motor & SC [LV 240]. One thing I attribute the low temps to is the superb Wohlt wire drive and ball bearing strut - less parasitic driveline drag. I can't imagine where you'd fit a 6S pack BTW - my 4S Turnigys just make it.
Not to rain on your parade, but the Duece has been redesigned to run better with the .18 nitro motor instead of the .21 that came with the previous MV and some nitro racers have reported instability at speeds much over the mid-forties ; confirmed by Mike Z. who has a hand in designing the AQ Vegas boats. Just so you know
As been pointed out in previous posts, this video was a one-time event. While untaping, the boat exploded and all that was left of Brad, who was helping, was his shoes. Authorities are still searching for the poor lad.Last edited by properchopper; 06-03-2010, 09:38 PM.2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
Hi proper chopper whats the castle creations equivalent to that motor or will the neu give more power ?? Also what prop thxPrince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.Comment
Ok thanks properchopper what esc then ??Prince 25 8XL,Delta force 29 8XL, SV27,Rio 51,Mini Rio,Stock Miss Geico m445,ERBE,Baja 5B SS, Hyper ST, Castle Emaxx.Comment
