Hopefully this is a simple question. I just bought a Speedmaster Stinger for a .187 cable. There is an 1/8 indentation that is a 1/4" diameter on the transom side. A 1/4" brass tube fits perfectly in that hole. It looks like I leave about 1/8" of the brass tubing sticking out when I mount it on the boat and then the stinger mounts to the transom. My question is, is it ok to run .187 cable through a 1/4" tube with no teflon? My other choice is to use 9/32 tube with a piece of teflon tube sticking out (1/4" diameter) and push that into the stinger. What do you think is the best way.
Stinger to stuffing tube
http://www.offshoreelectrics.com/pro...at=Flex+Cables
See suggested stuffing tube sizes with / without teflon liners -
your not going to fit a liner in the 1/4 tube and run a .187 cable, only the liner for a .150 and a .150 cable fit in the 1/4 inch tube.
I run the .187 cable and no liner in the 1/4 tube works great! the suggested brass tube size that OSE reccomends for the .187 cable seems off, it runs way to hot in the 7/32 brass tube even with grease or oil, i tried, and the brass tube had holes in after one run from the cable.Comment
If all of your wishes are granted, many of your dreams will be destroyed!Comment
Jeepers thanks for the info. I scanned the document that comes with the strut. It states that the copper tube should be 1/4" for a .187 drive shaft to work with the stinger. Yet it conflicts with the set up recomendations with OSE. I am going to go with the 1/4 inch as you have unless someone enlightens me further. The only other option is 9/32 with a teflon liner as recommended by OSE. That liner is so tight I am not sure I can get it fed into the tube unless I oil it down quite a bit. It does appear to be about 1/4" in diameter which would also fit into the stinger.
I have the 7/32nd tube also and it seemed pretty snug to me. Thanks for letting me know about that.Attached FilesComment
If I were building a mono and used the .187 cable, personally I would use the 9/32 tube and liner, mostly because I think it helps keep water out of the hull better. Also the tube is enclosed in the hull, (unlike a hydro) and not causing any drag in the water.Comment
