Strut Bushing Measurements
  • j.m.
    • Jul 2008
    • 838
    Hey everybody,
    I was wondering if anyone with a set of calipers would mind taking some measurements of their bushings and matching 3/16" prop sfafts(from the same setup/manufacturer). I am going to be making my own stainless hardware...
    Dimensions:
    Bushing length
    Bushing OD
    Prop Shaft Length (from cable end to drive dog)
    Thank you!!!!!
    Jon
  • crabstick
    • Jul 2008
    • 954
    i just use K&S brass tube, next size up from 3/16 whatever that is
    Matt.
    FE, Nitro and Gas racing in Auckland
    www.rcboats.co.nz
    • Jeff Wohlt
      • Jan 2008
      • 2716
      I would not use SS bushing and SS shaft. Brass and SS makes a much better surface. The reason you see all the German and other makers use it.
      www.rcraceboat.com
      [email protected]
      • BHChieftain
        Fast Electric Addict
        • 1969
        My other hobby is archery and I have several take down longbows which come apart at the riser. They are always made with the outer sleeve steel, and the inner sleeve brass. The brass is softer and confirms where it needs to.
        -Chief
        • j.m.
          • Jul 2008
          • 838
          That's what i'm doing guys...
          I want the measurements of a strut bushing because I want to use a common strut bushing inside the stainless outer tube. Just like a standard speedmaster strut, but swap aluminum parts for SS.
          Jon
          • j.m.
            • Jul 2008
            • 838
            Here's some quickies I drew up in SW to show what i'm talking about:
            Bushing is .1875" ID .24" OD end nub is .125" long .375" OD
            Strut bottom tube is .245"ID .375" OD; 15* chamfer on leading edge.
            Strut blade is .125" thick 1" wide, 2" tall; 15* chamfer on leading edge.
            Jon
            • j.m.
              • Jul 2008
              • 838
              Anyone?
              Im about to just order a Speedmaster bushing....
              • j.m.
                • Jul 2008
                • 838
                Hellooooo....
                Nobody has a strut bushing and a set of calipers?
                • crabstick
                  • Jul 2008
                  • 954
                  I meant to reply to this yesterday, but i had epoxy over my fingers, will measure when I get home, just took the strut off my whiplash last night.
                  Matt.
                  www.rcboats.co.nz
                  • j.m.
                    • Jul 2008
                    • 838
                    Thank you!!!!
                    I think I've got a good plan, I just don't know what size tubing I need.
                    Jon
                    • crabstick
                      • Jul 2008
                      • 954
                      ok nearly forgot!
                      Looking pretty close to 5.1mm, my good calipers are no longer good so these may not super dooper acurate, but pretty close
                      Matt.
                      www.rcboats.co.nz
                      • tanasit
                        • 65
                        I just happened to remove the old bushings and reeplaced them with the lead teflon bearing. There were 2 old ones with length of 0.198" each and I replace them with 2 longer lead teflon at 0.384 each.
                        Dimensions:
                        Bushing length = 0.384"
                        Bushing OD = 0.237"
                        Prop Shaft Length (from cable end to drive dog) = 1.117" this is from the end of the drive shaft to the forward edge of the drive dog.
                        Hope it help.
                        • j.m.
                          • Jul 2008
                          • 838
                          What bushing brand was this that you used? Crabstick, you too.
                          Thanks for the diagram, great help.
                          Jon
                          • crabstick
                            • Jul 2008
                            • 954
                            I have never bought a bushing in my life, I make my own using K&S Brass tube, I find the longer the better.
                            Matt.
                            www.rcboats.co.nz
                            • j.m.
                              • Jul 2008
                              • 838
                              Huh. Do you put holes in it like this?
                              So I take it you also make your own hardware... :D
                              Jon
