Velocity Mono
  • HappyOne
    • Jul 2008
    • 179
    Velocity Mono
    Just got this on Friday (thanks Jim) and I have run it three times so far. I am trying to get it set up so it will run smoothly and self right 99.9% of the time.
    I have adjusted the driveline with about 1 degree down and reset the turn fins slightly. The battery placement seems to be key and in this picture it shows the best position I have found so far.
    Who has/has run one of these before with these batteries (same ones I run in my micro hydro) and can make any suggestions to improve handling and self-righting?
    Stock and with the battery back a bit more, it would get a wicked speed wobble at full speed and dump and stay on it's back
    Sorry, crappy cell phone pictures.
    Grand River Marine Modellers, el Presidente
    IROC VUP, 25" Prince Mono, Mini Hydro, Classic Barrel Back, brushless Mini Rio and two Nitro Tunnels
  • LiPo Power
    DJI Drone Advanced Pilot
    • May 2009
    • 3186
    ...you need to swich to 5.5mm connectors...
    Ooo and I am sure the is the problem....
    Robert
    Canada
    • scubasteve95
      • Apr 2010
      • 239
      your boat looks good..
      go to the velocity thread on 1st page of this forum...
      i have same boat and i think you will find this interesting...
      i have(HAD) the same problem...but not anymore...wfo now.........
      • HappyOne
        • Jul 2008
        • 179
        What did you do?
        I started mounting the battery further back and that has helped.
        • scubasteve95
          • Apr 2010
          • 239
          Originally posted by scubasteve95
          don't ever think of buying this boat from anybody
          but jim(sailr) even if his is twice the price(and its not)
          thanx to him my boat is kicken a$$....
          dead heat against my buddys jollymotor(but cut turns like a knive)
          got pics.....
          actually the stickers get me only another 3mph but i'll take what i can get..lol
          sailr is correct as far as handling goes but i also added the jollymotor rod boot
          and turned the rudder assembly around and theaded the hole so i could add a nylon screw for the rudder safety.
          also tinned the flex cable end for a snug fit and to
          stop the damage from the set screws
          What did you do?
          check this out and see the thread
          • scubasteve95
            • Apr 2010
            • 239
            Velocity series by MiniCatRacing...this is the thread
            • scubasteve95
              • Apr 2010
              • 239
              Originally posted by bigwaveohs
              I have one of these and have never had a problem with self-righting. Move the batteries further back...
              trim tabs made mine rock solid..even in chop....
              • Doby
                KANADA RULES!
                • 7277
                Its a floating speed bump for our larger boats
                • scubasteve95
                  • Apr 2010
                  • 239
                  Never had a problem with "speed wobble" chine walk or self righting...always pops back up and skips right over chop. Don't need tabs either. If you get the CG right there is no problem with 3S1P 2200 mAh batteries...the boat rips...
                  no offence but,
                  looks slow??????
                  have you checked your speed???????
                  i going to say mid 20's
                  this is why you dont have any chine walk.......
                  • scubasteve95
                    • Apr 2010
                    • 239
                    If the boat chine walks you have exceeded the maximum hull speed...just like us big boys...and it can be very scary!
                    boat is stock...just wicked fast for its size...
                    added trim tabs and can hold WFO all day long...
                    speeds @ 29-31mph on gps
                    notice the jollymotor has to keep cuting the courner to keep up...
                    • scubasteve95
                      • Apr 2010
                      • 239
                      going to get a higher kv motor this
                      week...lets see how fast we can get this little boat running
