New Water cooled Outrunner design
  • Jeff Wohlt
    • Jan 2008
    • 2716
    Saw this and thought it was pretty neat design. Wish they would make them larger. RPM is there but wonder about torque.
    The neat thing is how they are getting water thru it.
    www.rcraceboat.com
    [email protected]
  • andym
    More Go Than Show Prop Co
    • 2406
    I like it !!! Now for BIG one's please say 3000 watts continuous and 2200 kv
    • Xfactor
      Banned
      • 861
      I told scott hed make some money if he made these coolers for outrunners that dont have them like his screamer but no response.
      • Jeff Wohlt
        • Jan 2008
        • 2716
        Well the rpm is there for smaller boats but not sure how much it can take. Might be worth trying one on 2S and a 25" boat.
        www.rcraceboat.com
        [email protected]
        • Steven Vaccaro
          • 8723
          They are cooling the front motor plate and bearing. A similar result can be had with a cooled motor mounting plate.
          • Jeff Wohlt
            • Jan 2008
            • 2716
            Look at the flow...it goes around the motor...not just the front plate.
            www.rcraceboat.com
            [email protected]
            • Steven Vaccaro
              • 8723
              Thanks for pointing that out. If thats the case, its quite cool literally!
              • Steven Vaccaro
                • 8723
                Found a little picture there.
                • crabstick
                  • Jul 2008
                  • 954
                  very cool
                  Matt.
                  FE, Nitro and Gas racing in Auckland
                  www.rcboats.co.nz
                  • daveives
                    • Jun 2009
                    • 109
                    Twice the power with Direct Water Injection
                    Take a look at this thread, done with a larger motor.
                    http://forums.offshoreelectrics.com/...ight=outrunner
                    I tried the setup with 6S, and it was uncontrollably overpowered, flipped, wiped out my eagle tree recorder. This works with a jet screamer 1400 as well, easy to retrofit existing motors! I estimate that you can double the power level limits.
                    • sailr
                      • Nov 2007
                      • 6927
                      It sounds like he's just dumping water inside the motor, not through a
                      'channel'.
                      It seems to me that putting water into any moving part would really slow the motor down or cause it to draw a lot of amps because of the drag?
                      Mini Cat Racing USA
                      www.minicatracingusa.com
                      • daveives
                        • Jun 2009
                        • 109
                        Just try it.
                        That is right, no channel, just dumping into Jet Screamer from top, and HB from bottom were it gets drawn up with the air pumped by the built-in centrifugal pump in the HB.
                        The amount of water is small compared to the power level so the motor is not significantly slowed down. Try dripping some water into a running outrunner and see for yourself. Then try completely immersing a running inrunner with vent holes at the ends. You will likely be surprised.
                        • LiPo Power
                          DJI Drone Advanced Pilot
                          • May 2009
                          • 3186
                          May I ask where you got this picture from, please?
                          I would like to see larger version of it....
                          Robert
                          Canada
                          • ReddyWatts
                            • 1711
                            It is on a photo in the first message link. I was beginning to think no one was going to notice this cooling feature.
                            ReddyWatts fleet photo
                            • LiPo Power
                              • May 2009
                              • 3186
                              Thank You.
                              Canada
