Stacking thrust bearings?
  • BHChieftain
    Fast Electric Addict
    • 1969
    I'm using a new coupler (flex hex), and it leaves too much room between the motor casing and the back of the coupler for only 1 thrust bearing. Would it be ok to use 2 or 3 "stacked" thrust bearings to fill the gap? Seems like this would be fine but thought I'd check...
    -Chief
  • Steven Vaccaro
    • 8723
    I've done up to two of them. You can also cut the shaft a bit.
    • Jeff Wohlt
      • Jan 2008
      • 2716
      I would cut the shaft. It is better.
      www.rcraceboat.com
      jwohlt5362@yahoo.com
      • BHChieftain
        • 1969
        Egad... cut the shaft on a brand new neu motor... makes me cringe!!!
        -Chief
        • ED66677
          • 1300
          if you can't properly drill the coupler deeper, cut the shaft then!
          Emmanuel
          • FighterCat57
            "The" Fighter Cat
            • Apr 2010
            • 3480
            -Chief
            JMHO- Make several cuts in very small increments. Make sure you still have enough coupler to reach the drive too.
            ________
            Suzuki boulevard s83
            • Jeff Wohlt
              • Jan 2008
              • 2716
              just be sure and tape and holes shut so the metal dust does not get sucked in from the mags...they are strong!
              www.rcraceboat.com
              • BHChieftain
                • 1969
                I'm swapping in a neu 1515 for a feigao 540XL. For my application, the feigao drive shaft is the right size, and the neu shaft is longer. So unless I want to make a bunch of other adjustments, the simpliest path does seem to be to trim the 1515 shaft.... wish me luck...
                I'm thinking about using the cutting wheel on a dremel tool. Is that an ok approach?
                -Chief
                • Jeepers
                  • May 2007
                  • 1973
                  -Chief
                  Yep it works just fine.
                  • BHChieftain
                    • 1969
                    Operation completed without incident... dremel cutting wheel worked well.
                    -Chief
                    • crabstick
                      • Jul 2008
                      • 954
                      doh i was just about to say you could have made a spacer plate for the mount and used longer bolts..
                      Block of alloy, drilled and watercooled
                      Matt.
                      FE, Nitro and Gas racing in Auckland
                      www.rcboats.co.nz
                      • BHChieftain
                        • 1969
                        Next motor perhaps!
                        -Chief
                        • Jeff Wohlt
                          • Jan 2008
                          • 2716
                          Some shafts are just too long. Only takes 10 seconds and a file to smooth the burs off and you are set.
                          www.rcraceboat.com
