Just wondering on some of these cheap himodel, mystery and suppo, etc ESCs how you all set them up.... soft start, hard cutoff, auto throttle auto range setting or 1.1-1.8, etc
Also, my end caps are getting pretty hot and I have epxerienced shut downs so I probably need the extra caps on it to run it cooler. THought the LVC was hitting but not with full lipos so I set it to soft and can see it slowing. Then she comes back up after a few seconds.
I am running a MM with 9Xl and X442 prop with this one.
Give me any thoughts you have. Timing on this one is only two ranges...2-4 pole and then outrunner timing....high. It is water cooled and the rest is only warm after some hard running but the caps are hot.
Thanks,
Thanks,
