For those of us me included who thought the chinese esc are a viable alternative to the hydra's read these emails from the bottom. I have recently purchased two hydra 120's and yes one was stuffed on first use but there warranty will FIX IT NO PROBLEMS the feigao on the other hand.As I have said on RRR check out the dates I think they thought I would just go away.NO CHANCE but I will happily let every know if they eventualy replace it.
have tested this plate when you stated that this was caused by water.I used main tap pressure wich is way over any pressure from running boat and it did not leak a drop.
----- Original Message -----
To: andym
Sent: Wednesday, September 05, 2007 6:35 PM
Subject: Re: what are you doing about it
Please just send me a picture for reference. We just want to make sure that this won't be a problem for ESC burned. I'm asking for special approval for your ESC replacement and need more information.
To: FEIGAO-Alex.net
Sent: Wednesday, September 05, 2007 4:56 PM
Yes I did not send back to Allan by mistake if you wuold like it I will happily post to you.
To: andym
Sent: Wednesday, September 05, 2007 6:19 PM
So you still have the cooling jacket ?
To: FEIGAO-Alex.net
Sent: Wednesday, September 05, 2007 4:40 PM
Yes they are sold that way from Aztec models in the UK
To: andym
Sent: Wednesday, September 05, 2007 5:59 PM
Hi Andrew,
Do your ESC have water cooling jacket on it?
Regards,
Alex
To: tradingmate@163.net
Sent: Wednesday, September 05, 2007 4:22 PM
Subject: what are you doing about it
Would like to know what you are doing about your exploding esc? All products have some warranty, and will be giving my remaining esc to a electrical engineer to find out how it torched itself.
Original Message-----
Sent: Wednesday, 29 August 2007 8:40 AM
To: 'FEIGAO-Alex.net'
Subject: RE: Failed ESC
As I said in my earlier email that the boat went 30-40 mtr onto the
lake. By the time we retrieved it that is what was found. Yes I find it
hard to believe as have had a esc failure before and this was definitely
way beyond anything I have experienced or seen before. Quite scary when
you think the only reason my boat did not burn is because the hull is so
well sealed that the fire would of gone out due to lack of oxygen.
-----Original Message-----
Sent: Tuesday, 28 August 2007 6:20 PM
To: Andrew Midgley
Subject: Re: Failed ESC
Hi Andrew,
Ok, let me try to understand: it was just a test on the ground. When
power up and test ESC, it burned. right? Normally burn MOFETs only
happened on power module part. But we can see from your pics, all
circuit pack burned include control board. We've never face this kind
of situation. So we'd like to know more details what happened. What's
your test conditions.
Please advise.
Regards,
Alex
From: "Andrew Midgley" <Andrew.Midgley@elders.com.au>
To: "FEIGAO-Alex.net" <tradingmate@163.net>
Sent: Tuesday, August 28, 2007 7:03 AM
Alex I live at 214 morish st Broken Hill NSW Australia 2880. This esc
was lieraly just put in boat to make sure it was Ok as it was purchased
as a spare. The boat is a toysport triton running feigao 9xl, 5s lipo
and at the time a x442 cf prop. It went approx 30-40 mtr onto lake and
stoped, then bang by the time we got it back ,well you have seen the
results. It at NO time got wet. This hull is the driest I have.
Sent: Monday, 27 August 2007 5:25 PM
To: Andrew Midgley
Hi Andrew,
Please let me know where are you from and let me know more details about
this case.
Regards,
Alex
Sent: Monday, August 27, 2007 8:56 AM
This esc did NOT get wet was not even under much load. Lucky it did not
torch my boat or it would cost YOU more than your esc. It is pity really
as I like these esc but your lack of warranty means I will no longer
purchase your products and don't worry I will most definitely Tell
everyone who will listen on the rc forums Not to use your product
ether..!!
Sent: Wednesday, 22 August 2007 1:15 PM
To: Astec
Hi Allan,
Thanks for your information. Based on your photos, i think that this ESC
was damaged due to water issue. It's not included in warranty.
Any further questions or comments, please feel free to contact us.
Regards,
Alex
Sent: Wednesday, August 22, 2007 3:31 AM
> Alex,
> Pics attached. I have asked for more details - eg, calm or rough, time
> into run etc.
> Allan
> FEIGAO-Alex.net wrote:
>> Hi Allan,
>> Thanks for your email. What do you mean charcoal lump? If the
circuit
>> pack totally damaged, we need to know what's the problem is.Please
>> also ask your customer more details. A picture of it will help.
Please
>> let me know your comments. What we provide is limited warranty, which
>> means no burn on circuit pack and ESC doesn't work.
>> By the way, this is for boat applications, right?
>> Regards,
>> Alex
>> ----- Original Message ----- From: "Astec" <astec@astecmodels.co.uk>
>> Sent: Tuesday, August 21, 2007 1:51 AM
>>> Nothing left to evaluate - it's a charcoal lump - would a picture
do?
>>> Allan
>>> PS - can I get more as samples?
>>> Thanks
>>> Allan
>>>> Hi Allan,
>>>> Please send back to us through air mail for evaluation.
>>>> Regards,
>>>> Alex
>>>> To: "Alex Cai" <tradingmate@163.net>
>>>> Sent: Sunday, August 19, 2007 2:40 PM
>>>> Subject: Failed ESC
>>>>> Alex,
>>>>> I have a failed 100 amp esc here. It blew on the first run after a
>>>>> few second bing tested as a spare.
>>>>> Can you replace?
>>>>> It was running 5s lipo Feigao 9xl Octura X442 prop. The other esc
>>>>> works perfectly (also a 100 watercooled)
>>>>> Thanks
>>>>> Allan
>>>>> Allan Shillitto
>>>>> AsTec (Models and Electronics)
>>>>> www.astecmodels.co.uk
>>>>> Fast Electrics a speciality.
>>>>> www.mozilla.org for Firefox next generation browser Thunderbird
>>>>> next generation email
To: andym
To: FEIGAO-Alex.net
To: andym
To: FEIGAO-Alex.net
To: andym
Hi Andrew,
Regards,
Alex
To: Andrew Midgley
Hi Andrew,
Please advise.
Regards,
Alex
To: Andrew Midgley
Hi Andrew,
this case.
Regards,
Alex
ether..!!
To: Astec
Hi Allan,
Regards,
Alex
> Alex,
> into run etc.
> Allan
>> Hi Allan,
circuit
Please
>> Regards,
>> Alex
do?
>>> Allan
>>> Thanks
>>> Allan
>>>> Hi Allan,
>>>> Regards,
>>>> Alex
>>>> Subject: Failed ESC
>>>>> Alex,
>>>>> Can you replace?
>>>>> Thanks
>>>>> Allan
>>>>> Allan Shillitto
