Cutting a flat spot on a motor shaft
  • BHChieftain
    Fast Electric Addict
    • 1969
    I need to cut a flat spot on the motor shaft for the coupler set screw. I was planning to secure the shaft with a vise and use a grinding wheel with a dremel tool freehand. Before I destroy the motor shaft, any tips?
    Thanks,
    -Chief
  • Rumdog
    • 6453
    Take a ziplock bag and pull it over the motor. Push the shaft thru the bag so do dust gets in the motor or bearigss. You shouldn't need to hold it in a vise to do it. I've had good luck using a cutoff wheel as well, moving it back and forth across the shaft lightly. You only need a small flat oon the shaft. no need to over do it.
    • Rumdog
      • 6453
      I think i got the Ziplock tip from Steven in another thread A while back.
      • Steven Vaccaro
        • 8720
        Any I got it from some other forum user.
        I forget who to give credit to. But its a dam good idea and makes clean up a snap.
        Steven Vaccaro
