SV ESC and a 10xl
  • electric
    • May 2008
    • 1744
    SV ESC and a 10xl
    I have hooked up a SuperVee esc with a 10xl fiegao motor. I figured that the 10xl is roughly the same type of motor as comes with the SV. The boat is a nostep m&H that is 23" long. Think it will not fry with a small prop??
    • 9488
    the XL is much bigger and will pull more amps than what the speedo will allow plus the kv is much lower
    a 12L is a much better choice, faster and pulls less amps
    • Doby
      KANADA RULES!
      • 7280
      I run a SV controller with a 9xl for years in one of my boats,,just watch the prop and you will be fine.
      Grand River Marine Modellers
      • electric
        • May 2008
        • 1744
        Thanks Doby, I am going to test it out today, we will see how it goes. I am just going to run it with some CF props that are small.
        • electric
          • May 2008
          • 1744
          Well, it ran great! Really a nice boat and very fast. I need a new GPS to get some numbers, but it was covering the entire pond very quickly. Ran it for about 4 minutes and the temps looked good on everything. I just used a CF 3blade that comes with the SV. That worked well. I have some new props coming in this week so I will give them a try.
          • Doby
            KANADA RULES!
            • 7280
            I run the 9xl in a Blackjack with that conrtoller and a SV prop and it hits the 40mph mark with good temps consistently. Glad it worked well for you.
              • 9488
              that's awesome you can use an XL with this esc!
              • Flying Scotsman
                Fast Electric Adict!
                • Jun 2007
                • 5190
                As Doby mentioned be very carefull with the application...prop, boat etc.
                That Esc is not rated for high amp/voltage applications.
                Nanny Douggie
