I'm trying to find out how much power a P-spec power system has, specificly the UL-1 system because I hear that it is the best and what folks are running in their JAE21s, but I would be interested in hearing about the SV27 and BlackJack systems too for comparison, has anyone run an eagletree or other datalogger on their P-Spec boat? Or if you have run down to LVC and timed the run I would be interested to hear what runtime you got.
If all you Pspec runners could list your setups and amp draw/ run time i would appreciate it, I am after the following info:-
Boat Class: P-Spec hydro, P-spec offshore, P-spec tunnel, etc.
Motor: UL-1, SV, BJ, or any other your club allows.
ESC: is it the stock ESC for your motor or are you using another, if so what is it, if not do the rules restrict you from doing so or is more just not needed for that motor?
Cells: I assume everyone is on 4s but are you all on 4s1p or is anyone using 2p? What brand, capacity and "C".
Prop: For myself I don't need to know what prop you are using, the info I am after is just, what stops you from propping up further? Motor heat, insufficient motor torque dropping the revs too much, ESC heat, runtime etc. However if you are willing to disclose it, I'm sure there are many potential P-speccers that will read this and could use your make/size/mods info too.
Amps/Time: If you have Eagletree data, a graph would be ideal but peak and base amp draws would be fine, what sort of voltage the cells are dropping to would be helpfull too preferably form somewhere in the middle of the run. or if you have run from fully charged cells to the LVC what was your runtime? with the runtime and the cells you use we can work out the average amp draw
Note.
I am not trying to offend sport boaters here but if you spend long periods of time at partial throttle rather than just backing of for an oval corner then getting back on it for the straight then whilst your Eagletree data would be valid for my purposes your runtime data wont be so please make sure that in the runtime section you note that your time includes extended partial throttle usage.
If for example you have a SV27 and everything runs cool but you don't prop up because whilst faster the boat flips all the time, then that is fine and you made the sensible decision, but what I am trying to ascertain here is the maximum capabilities of the P-spec power systems alone, not that of the hulls they came out of or get fitted in so if that is the case please make sure that in the prop section you put that the Hull is what stops you from propping up further.
SAWrunners/2lap racers, can you make sure that you put in the runtime section that is what you do and that the motor/esc may overheat running a full race distance, and a note in the motor and ESC sections saying that they are uncooled if you don't run watercooling would be good.
Here's a template to make it easier for you to reply, cut/paste it then fill in the blanks.
Boat Class:
Motor:
ESC:
Cells:
Prop:
Amps/Time:
Thanks in advance for your participation, you rock!
Note.
Boat Class:
Motor:
ESC:
Cells:
Prop:
Amps/Time:
