Power Glitches
  • INTERGRATING
    • Jan 2010
    • 16
    Power Glitches
    hello,
    Just installed a new swordfish esc. I have a power glitch when running mid to full throttle, somtimes low throttle getting the hull to plane. This happends with 2c1p and 3c1p. Boat will go then studder with throttle steady I have tried the lvc on auto and manual settings. With the boat out of the water the throttle seems to respond fine. This happens 80% of the time when slowing for turns. I have also calabrated the throttle stick as recomended. Any one had to fix a sporatic boat before?
  • Doby
    KANADA RULES!
    • 7280
    How good are your batteries?
    Crappy cells can "seem" fine with no load (out of the water).
    Grand River Marine Modellers
    • Meniscus
      Refuse the box exists!
      • Jul 2008
      • 3225
      What is the motor and what do you have the timing set to?
      • INTERGRATING
        • Jan 2010
        • 16
        New batts less than 10 cycles, tryed a MNHI batt, worked fine.
        • INTERGRATING
          • Jan 2010
          • 16
          I am using a proboat 2900kv motor out of widowmaker.
          The timing for the esc is set to the default setting(not to keen on this setting)- Auto
          The PWM rate (dont know what that does) set to default- 8KHz.
          I do see a throttle range in the manual for 640uS - I am using the original rx,tx from proboat.
          • solidsnake454
            • Oct 2010
            • 9
            ive got the same motor and similar problem fully charged batts i even put it on nimh to make sure lol i think it was the initial torq setting soft or hard sart limits the load that can be placed on the esc example you gun your boat and it cuts off but you can ease into the throttle slowly to full let off and gun it it cuts off lol every time try it and see
            How many amps do i need ? screw it let it burn.
            • NativePaul
              Greased Weasel
              • 2761
              Have either of you tried using a receiver pack instead of the BEC? If not that is the first thing I would try.
              • solidsnake454
                • Oct 2010
                • 9
                havent thought of that yet can i use the rx pack for my gas plane in it ? if so how do i go about hooking it up ?
