kb 45xl speed controler
  • skidooguymxz550
    • Jun 2007
    • 242
    i have finally got my dads challenger running reliably on a 14xl on 20 cells with a hydra 120. the problem is this setup is to much power for the hull. she goes great in smooth water but after a few laps are made and she runs in her own wake it chine walks like crazy. we choose the deep vee for it's rought water capabilities and she's running like a hydro
    what we want to do is go to a 39" fountain or a 43" challenger. will the kb45xl be within the limits of our speedo? will this setup still power us into the mid to high 30's? will 8-12" make a difference in her rough water capabilitY?
    thanks
  • ReddyWatts
    • 1711
    If your motor is a KB45, are you sure it is a 14XL or is it a Feigao?
    ReddyWatts fleet photo
    • Steven Vaccaro
      • 8723
      thanks
      Most all the boats in that Challenger size range will run well in 2-4" chop at around 25-30mph. Once the wind picks up and the waves get larger, all has changed.
      The 45kb will be in the 70-100 amp range. I would feel more comfortable running a higher amp esc.
      • skidooguymxz550
        • Jun 2007
        • 242
        sorry. i should have been more clear, it's a fieago but with a bigger hull we'd go to the bigger motor
        • ReddyWatts
          • 1711
          A KB45/9XL on 18 cells using a Hydra 120 with a X642 prop should use 90 amps and run about 35-40 mph at 25000 rpm for a large hull..
          An X640 prop will use 80 amps at close to the same speed, but not sure how well it will get that size of boat on plane.
          • skidooguymxz550
            • Jun 2007
            • 242
            so it sounds like i'm good to go?
            could i do a 11xl on the 20 cells? do to my chargers i can only have up to 8cell packs so what i use right now is two 7 cells and one six cell
            • ReddyWatts
              • 1711
              Fiegao or KB45? I would recommend a KB45 10XL if you are using 20 cells, 75 amps on a X642 at 24000 rpm, same speed. The Fiegao is too small for a 34 -45" hull, without a trans.
              • skidooguymxz550
                • Jun 2007
                • 242
                why am i so retarded today?
                i meant the 11turn kb45
                • ReddyWatts
                  • 1711
                  I think Steven only sells a 12,10,9 and 8xl in the KB45?
                  • ReddyWatts
                    • 1711
                    Ha I have my moments too. The 11XL is for a higher voltage setup, but I will look at it for you.
                    • ReddyWatts
                      • 1711
                      11XL 60 amps, 30 - 35 mph at 21000 rpm using a X642 prop.
                      70 amps on a X645 at 23000 rpm at 32-38 mph.
                      I still like the KB45 10XL if you are using 20 cells, 80 amps on a X642 at 24000 rpm, running 1800 watts.
                      If you wanted to really push the 10XL over 40, a X645 prop using 100 amps at 23000 rpm 2300 watts. Just need to really watch your temps and raise the strut if running a cat.
                      • SJFE
                        • 4735
                        How many volts is that on Mr Watts?
                        • ReddyWatts
                          • 1711
                          20 NiMH cells for 24 volts.
                          10XL on 6s Lipo's is 70 amps on a X640 for 40mph at 25000 rpm, if all of these new numbers are correct in FeCalc.? Need someone to test them. They should be in the ball park.
                          • skidooguymxz550
                            • Jun 2007
                            • 242
                            thanks for all the help man. i think i have an idea of what to do now
