Motor question
  • speedsport
    • Mar 2010
    • 49
    Motor question
    Would any one have a idea what kind of amps a 8900Kv motor would pull?
  • Flying Scotsman
    Fast Electric Adict!
    • Jun 2007
    • 5190
    Sorry, you will not like this answer. That is a dumb question...8900Kv ?????
    Douggie
    • mappo
      • Feb 2010
      • 488
      8900kv
      OK Mr Scotsman, Be nice! maybe this guy is a newbie
      Do you know what the biggest problem with the world is?
      That the Smartest people are full of doubts while the stupid ones are full of confidence.::tt2
      • Jeepers
        • May 2007
        • 1973
        Douggie
        Why is that a DUMB question Castle makes a CM36 9000kv motor for 1/10 scale on road cars......................
        speedsport a little more info would be helpful like, what do you planing on putting it in? 8900kv is way to high for boat use unless you are running a very small boat on one 3.7v lipo
        • Flying Scotsman
          • Jun 2007
          • 5190
          Answer..no boat...no prop...no battery and 8900Kv.
          That is why I responded that way. Newbies do some research first and most of you do.
          Douggie
          • Jeff Wohlt
            • Jan 2008
            • 2716
            The only way is using a gearbox for that. That is the difference in boats and cars.
            We used to run lots of gear boxes with big props. 8900KV is pretty extreme but certainly could be geared right for smaller rigs.
            www.rcraceboat.com
            jwohlt5362@yahoo.com
            • speedsport
              • Mar 2010
              • 49
              I am new to brushless and new to electric boating. Ive only had nitros in the past.
              Where would I find gear boxes for some thing like this? The motor is quite small in physical size. I'm into the mini and micro boats.
              • m4a1usr
                Fast Electric Addict
                • 2038
                The only 2 gearbox setups I know of are the FDM tranny and the Hughey gearbox. Both are pretty big so they probably are not suited to small hull. I bet the heli and airplane community have something. Why not just get a small 380 or so motor and not spend money on a tranny? Small B/L motors are very cheap, much less then a tranny I bet.
                John
                Change is the one Constant
                • speedsport
                  • Mar 2010
                  • 49
                  Ok I have this hull http://www.bbyracing.com/elecmicrohulls.asp its The Micro Patriot. I have a 30A esc laying around and 1/8 flex shaft etc. What would be a good size motor and prop for this hull? I have a extra X427 prop but I think it will be to big. Also I would prob run it on a 7.4 lipo pack.
                  All though I see they use a X431 prop so it may work.
                  Thanks
                  • Jeepers
                    • May 2007
                    • 1973
                    Douggie
                    I know Douggie, it wasn't a dumb question, just a question with out a whole lot of info!!!!!
                    • video200
                      • 837
                      Thanks
                      on the page you refeered to they reccomend a 480 size motor and a X431 prop (in the artr)
                      klaus
                      • Jeff Wohlt
                        • Jan 2008
                        • 2716
                        Steve has some Short and long motors here. He is waiting on some 380Xls that would be a great match.
                        www.rcraceboat.com
                        • Rex R
                          • 992
                          methinks that if I were to go the brushless route, that one of these http://www.offshoreelectrics.com/pro...-380-L&cat=116 in either 7 or 8 turn flavours would work pretty well.
                          • Alexgar
                            • Aug 2009
                            • 3534
                            eflite 2700 kv 28mm x 47mm is what i use in my mini vee on 3s
                            • Alexgar
                              • Aug 2009
                              • 3534
                              I also use a stock mini vee prop which is close to a x431 as far as i can tell
                              my link
