kb45 vs. fegiao xl
  • steveo
    • 1454
    kb45 vs. fegiao xl
    could someone do a photo comparison with these two motors and post ,i really would like to see both together to get a better perspective.
    i would like to try the 2300kv version on 12 cells in a fdm 32
  • Steven Vaccaro
    • 8723
    http://forums.offshoreelectrics.com/showthread.php?t=21
    • steveo
      • 1454
      thanks, does anybody think i could see 35mph using the 1700 kv motor in a 32" mono
      • NorthernBoater
        • 811
        How many cells do you plan on using.
        • steveo
          • 1454
          12 cells for now
          • Mich. Maniac
            Banned
            • 1384
            So what is the diam. for the kb? will ose water jacket fit? which mount? I know they are a new addition to your stock but there isnt a whole lot of corresponding parts listed. 6mm shaft? will there be couplers made or just drill out old ones? Some questions have been answered but some remain un-answered.
            • Steven Vaccaro
              • 8723
              The water jacket is listed on the same page.
              If you click a details link you will find more info on each item
              Like this.
              http://www.offshoreelectrics.com/pro...rod=kb-45-11xl
              The couplers are listed with the couplers. It takes a 6mm shaft.
              • ReddyWatts
                • 1711
                The KB45 has a 6mm shaft. I went to a machine shop and it was going to cost me $27 dollars for the right type bit to drill it out. It could also shatter when doing this. I might try it in the future if I do not like the straight sleeve couplers that Steven sells. The mounting holes are also a different width apart on the Fiegao and KB45.
                Here is a picture with a Fiegao 10XL and a KB45 10XL, side by side.
                ReddyWatts fleet photo
                • Mich. Maniac
                  Banned
                  • 1384
                  you da man S.V. I wasnt trying to be a pain. just was blind.
                  • Mich. Maniac
                    Banned
                    • 1384
                    how about the poles? i guess thats what im looking for. how many?
                    • Steven Vaccaro
                      • 8723
                      2 poles on these motors.
                      • steveo
                        • 1454
                        thats a beast of a motor , what is the amp draw of these motors, does a kb45 10 turn pull the same as a 10xl but with more torque? or is it more effecient?
                        • ReddyWatts
                          • 1711
                          I think the KB45 10XL (1200kv) is going to be more like a fiegao 14XL (1196kv) with more torque. Not sure about the amp draw. I am finishing up a KB45 10XL build this evening. Hopefully I can post some data soon.
                          • SJFE
                            • 4735
                            If I am reading my DPR data stream correctly I was pulling on avarage 28.4 amps with a max of 80 amps. Thats on the 8XL @ 19 volts & a k42 prop pushing almost 8 pounds.
                            • ReddyWatts
                              • 1711
                              Did you ever figure out why everything was running so hot?
                              I am planning on starting out with a X440 prop, since I have no idea how many amps it is going to draw at 28.8 volts.
