Has anyone ran a hi-model on 8s? Of course im speeking of the 8s versions... If so can you tell me what your set up was.
Hi-model 200 8s?
Tags: None
I do, 36" balsa cat, 8s 5000mAh 30C Zippy flightmax, Neu 1521 2.5d, Himodel 4-8s 200A ESC with thermal pad removed from the heatsink which is attached to the FETs with thermal epoxy, I squashed 2 alloy tubes to fit between the 2 larger gaps in the heatsink fins making sure they were still wide enough for decent flow and thermal epoxied them in place, I then put heat shrink over the whole thing leaving plenty sticking past the ends, roughed up the inside of the heatshrink ends with sandpaper and filled the ends of the shrink with electronics grade acid free silicone sealant, when that dries I cut off any excess heatshrink. (I waterproof all my ESCs like that even if they allegedly come waterproofed from the factory like castles for a visible waterproofing that gives me peace of mind and can easily be cut off leaving no hindrance to a repair should it be necessary. Props are a mildly detounged and cupped x642 for racing and a stock x646 for spinting (races for this class boat (supermono) are 5 mins in duration with 10sec mill and in lap), The x646 gives 150A peaks on the eagletree.Paul Upton-Taylor, Greased Weasel Racing. -
I run one in my MM 9XL on 5s and in my T29 running a Medusa 3670 2300kv on 4s and they work great!
I'm going to bump the timing some this spring.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
I have yet to see a prog card for her... I have had several of these and also cool and water proof them. My question is has anyone ran these on (8) s. I ask because almost all of my setups are 4's set ups and now i would like to make 8s an option using these controllers if indeed they can handle it.Comment
perfect , thankyou.i do, 36" balsa cat, 8s 5000mah 30c zippy flightmax, neu 1521 2.5d, himodel 4-8s 200a esc with thermal pad removed from the heatsink which is attached to the fets with thermal epoxy, i squashed 2 alloy tubes to fit between the 2 larger gaps in the heatsink fins making sure they were still wide enough for decent flow and thermal epoxied them in place, i then put heat shrink over the whole thing leaving plenty sticking past the ends, roughed up the inside of the heatshrink ends with sandpaper and filled the ends of the shrink with electronics grade acid free silicone sealant, when that dries i cut off any excess heatshrink. (i waterproof all my escs like that even if they allegedly come waterproofed from the factory like castles for a visible waterproofing that gives me peace of mind and can easily be cut off leaving no hindrance to a repair should it be necessary. Props are a mildly detounged and cupped x642 for racing and a stock x646 for spinting (races for this class boat (supermono) are 5 mins in duration with 10sec mill and in lap), the x646 gives 150a peaks on the eagletree.Comment
The caps on these are 37V, so they should do great...NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
Ok, hate to push esc's to their limit. Ill do it anyway!Comment
Inspect your ESC before you assume the caps are rated to the full voltage. When the GX 200 first came out myself and others received them with 25 volt caps installed. That limited them to 5S at most. So dont assume. Otherwise your going to get a smoker and you will end up puzzled why the speedo smoked yet you knew you did not have a high amp setup. Its happened.
There are several programmers available from HiModel and was hoping someone found one that worked on the GX200. I have been using them with great success for awhile but I hate moving them around in different hulls to play around with because they are such a pain to program. Its a learning experience every time.
Assume!Inspect your ESC before you assume the caps are rated to the full voltage. When the GX 200 first came out myself and others received them with 25 volt caps installed. That limited them to 5S at most. So dont assume. Otherwise your going to get a smoker and you will end up puzzled why the speedo smoked yet you knew you did not have a high amp setup. Its happened.
John
First off I own 3 of these speed controls and the caps say 37V, and my 100A esc has a 50V cap!.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
Brushless 55 I believe he was telling Josh to be careful when he gets his controller????Inspect your ESC before you assume the caps are rated to the full voltage. When the GX 200 first came out myself and others received them with 25 volt caps installed. That limited them to 5S at most. So dont assume. Otherwise your going to get a smoker and you will end up puzzled why the speedo smoked yet you knew you did not have a high amp setup. Its happened.
John* BBY Lift Master RIgger * Insane Gen 2 Cat * Aeromarine Avenger Pro Twin * Delta Force Cyber Storm * Delta Force 41" Mono * H&M Viper II * H&M Intruder * OSE Raider Hydro * Whiplash 20 * Brushless Mini Rio *Comment
These speed controls will take 6s with ease..
And 8s without over loading the amps on them...NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
Hes correct, the EARLIER versions had the lesser caps on them. All of mine are the 37v caps. Thanks guys! Just wanted to hear from experience if people were actually running 8s through them.Comment
I'm going to try 8s on one of my 200s in a 3D plane I have for some speed runs..
I'm looking for 140mph in a Cap232!Last edited by Brushless55; 02-14-2010, 11:59 PM..NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
