Feigao 580l question
  • Matt C
    • Jun 2008
    • 52
    Hi All,
    Quick question, what wind 580l would you recommend putting into a cat(42").
    Running a twin setup and wanted some advise before purchasing, was thinking 9l?
    Thanks,
    Matt
  • Jesse J
    scale FE racer
    • Aug 2008
    • 7128
    What battery options do you have, what props, what is target weight? How fast you wanna go?
    "Look good doin' it"
    See the fleet
    • Matt C
      • Jun 2008
      • 52
      Jesse J, thinking 6s to start, have 51mm props which i'll probably replace, and want to go quickly:)
      • Steven Vaccaro
        • 8723
        I like the 580 9L with 6s. It will haul the mail.
        • focused
          Dutch Electric Powerboats
          • Jul 2008
          • 237
          This summer i am going to rebuilt the Andreas Schink Jolly 110cm (43") with twin setup feigao 580L8 , 6s lipo and 150 ETTI esc props starting with 42mm 3 blades .
          This isnt going to be just a fun setup .....:rockon:.....
          • Matt C
            • Jun 2008
            • 52
            focused - 8l , hmmm got me thinking now, still unsure which one to go and there ain't much in it. Was also thinking about trying the turnigy monster esc's, but will need to water cool (something else for me to learn but have a few ideas:))
            Ain't do so much math since i was a kid lol.
            • RCKong
              • Sep 2009
              • 1545
              yea they got these boats running 100+ mph now. if you go with the 580L I would not use the aluminum cooling jacket for it. It's massive and too much weight. Together with the motor is 689g X 2... go with some lighter means of water cooling for this sucker.
              • Rumdog
                • 6453
                The aluminum jacket is excellent. The added weight is nothing when you consider the size of a boat it is going into.
                  A few ounces means nothing to a boat with nearly 6 horsepower. My big cat only has 10S (not 12S like the OP's) and weighs almost 20 lbs - it kicks butt on gas cats. De-magnetizing an overheated motor is a far greater pain than loosing 0.002 mph due to an extra few ounces. And how on earth would anyone make an efficient reliable water cooler that weighs less??
                  • RCKong
                    • Sep 2009
                    • 1545
                    I buy acrylic and carbon fiber tubing and make my own very easily, and they work very well for a fraction of the cost and the weight. Aluminum ones for 2 of these motors are almost 1/2 pound due to their large size, I know I have one. If you want to tote an extra 1/2 lb on your boat well thats up to you.
                    • Rumdog
                      • 6453
                      That motor jacket weighs less than a 5 cell rx pack. Insignificant in the overall setup of the boat.
                        ...If you want to tote an extra 1/2 lb on your boat well thats up to you.
                        For those who don't have experience running large FE boats - I'll let you in on a secret. Weight is your friend. Most all large hulls have too much lift at the speeds we run them, so they blow off easily in anything but relatively calm water. To keep them on the water, we add weight. This counters lift, and helps the hulls from bouncing around so much.
                        The weight advantage is very evident when racing against the gas guys. Their boats weight about 4 to 5 pounds less than mine does, but I can handle race water much better. FE has the instant power to make up for the slight loss of acceleration from the added weight. I can still blow off, but I almost always finish the heat right side up under power. The average gas cat - not so much.
                        Now, you could add lead as weight, but it is a far better idea to add that weight as something functional. Hull thickness, stronger/better/heavier parts are preferable to lead.
                        If saving a few ounces on your boat makes you happy, by all means go for it. Just don't insist that it really matters - some of us actually know better.
                        • Matt C
                          • Jun 2008
                          • 52
                          Thanks for all the posts but still unsure whether to go for the 8 or 9 turn motors, can i ask all of your thoughts?
                          • Rumdog
                            • 6453
                            on 6s, id go with the 9 turn.
                            • Matt C
                              • Jun 2008
                              • 52
                              Rumdog- thanks for the quick response, if i moved up to 7s etc what would u say then?
