To stinger or Not to stinger?
    I raced a Pistolero 22 for years with a stinger, worked very very well. You do have to use a small one though....
    • Diegoboy
      • Mar 2007
      • 7244
      DuncanJerry (John) has your old yellow Pistolero22 in his closet. I heald that bad boy in my hand! I wish I got that one, because this white one I have needs HELP!
      • Jesse J
        scale FE racer
        • Aug 2008
        • 7119
        Stinger? I just met her.
        "Look good doin' it"
        See the fleet
        • Diegoboy
          • Mar 2007
          • 7244
          Jay, Where'd you get that Sitnger, if I may ask?
          • BakedMopar
            No Mo Slipah
            • Sep 2009
            • 1679
            Originally posted by Diegoboy
            I plugged the holes for NOTHING!
            It was good practice
            • Diegoboy
              • Mar 2007
              • 7244
              Here's her "NEWLY FILLED" transom. I think this enough for tonight.
              • Diegoboy
                • Mar 2007
                • 7244
                Let's see that "Before" pic again...
                • Diegoboy
                  • Mar 2007
                  • 7244
                  #23
                  Is that the same transom?
                  If I didn't know better, I'd swear that was a PhotoChop.
                  • screwball
                    • Jul 2009
                    • 464
                    #24
                    if i may ask, what was your method for filling all those holes because that looks like it just came out of the mold!!!
                    • Diegoboy
                      • Mar 2007
                      • 7244
                      #25
                      Sure. Let me run a few service calls and when I get back, I'll elaborate for you.
                      • Diegoboy
                        • Mar 2007
                        • 7244
                        #26
                        First, I remove all the HW. Remove the stuffing tube too. Get a big sanding block and sand the transom flat again. Once flat, Use hatch tape to cover all the holes in the transom. lay the transom flat (so that the bow of the boat is pointing up). mix up some epoxy with a pinch of microballoons. Next, pour the mixture into the holes in the transom. Once dry, peel the tape, and sand smooth.
                        • screwball
                          • Jul 2009
                          • 464
                          #27
                          ok cool, i assume that you threw a coat of primer over it after right?
                          • BakedMopar
                            No Mo Slipah
                            • Sep 2009
                            • 1679
                            #28
                            Thats the same method I used to plug the water outlet in the mini hydro. The ony difference is I layed some cloth on that. I just could not get in there with my short fat fingers.
                            • Diegoboy
                              • Mar 2007
                              • 7244
                              #29
                              White primer? Yes.
                              BakedMopar, She is looking good. What paint scheme do you have in mind?
                              • tth
                                • Apr 2008
                                • 1510
                                #30
                                Looking good Danny boy. I have a 41'' DF mono that is in need of a transom makeover. I was thinking of epoxying some carbon fiber plate to it. Now that I have seen your job I think I will do it like this. I'll save the carbon to make some motor and servo mounts.
