Sorry, but I gotta ask it...
  • NitroVal
    • Jun 2009
    • 423
    Im sure its been asked a million times, but what is the upper RPM limit a Neu/Fiegao motor will take. Lets say a 540, 60ish mm length can with a 442 prop on it.
    The RTR Nightmare- Electric King of Shaves
    Now with 540s- 62mph
    New setup- Etti 150A's, Turnigy 2600s, 5S, X442s and a whole lot of cooling hoses
  • domwilson
    Moderator
    • 4408
    A Feigao has 50k bearings and a Neu are 60k bearings. But you don't want to go near those RPM's on either if you want longevity.
    Government Moto:
    • ozzie-crawl
      • Sep 2008
      • 2865
      i think the upper rpm limits given for the bearings would only be used in a reduction gear system
      • NitroVal
        • Jun 2009
        • 423
        Yea, I know they have an RPM limit on the bearings, but that doesnt necessarily mean the windings or internals will stay together at that RPM, would they?
          The windings don't move so they fail by excess heat or scraped lacquer. Some magnets are cracked or not properly glued and will come apart long before 50,000 rpm. I have wound-out Fiegaos into the mid-45,000 rpm range under load, but I have seen others spit magnets at far fewer rpm. Because build quality varies, there is no real answer.
          • BakedMopar
            No Mo Slipah
            • Sep 2009
            • 1679
            I have had my feigao 12l at a little over 51000 rpm. I would not recommend it. I currently run my 380 8l on 3s so it's spinning above 43000rpm.
            • FloatDaBoat
              Bare Bones Fabricator
              • Sep 2009
              • 368
              Are those RPM figures based on motor KV ratings, or did you log them during actual runs?
              • BakedMopar
                No Mo Slipah
                • Sep 2009
                • 1679
                Those were logged. 12l was on 6s.
                • hide
                  • Dec 2008
                  • 188
                  Nic Case ran a Neu 1521 1Y at over 100k rpm in his speed car to run 161mph, that said I'm sure it will only last a few runs.
                  • Tuslow1
                    • 154
                    100,000 rpm, can you say high energy compact BOMB!!!
                    OK, You Go First!!!
                    • Simon.O.
                      • Oct 2007
                      • 1521
                      I have done a few or more passes, on different days, with a 540-7S on 3S to a 432 for a good mid 40krpm. I do not reccomend it if you want to use the motor next week.
                      It did work for me to pull over 100kmph (Police radar) with my smaller 26"rigger
                      • hide
                        • Dec 2008
                        • 188
                        I think the trick was that he geared the motor so highly that it never reached that. Although mathematically it should go over 100k he used a 3 speed gearbox to keep the revs down. Not too sure if he succeeded as I haven't seen him use the motor again
