Vision Tunnel
  • Kris Flynn
    #2 Bench Racer
    • 229
    #46
    Guys, what I was saying in that post was that if you set it to 35%+ it WILL nose steer...just like if you set the Vision at 32%+
    Not that I have set the CoG on any of my Visions to that far forward...
    I have seen the Cobra run and it does run well, But I still prefer the overall looks of the Vision and I know for sure that it can run into speeds of 60MPH + with ease. Not that our P-Spec setups will get near that just yet
    • Darin Jordan
      • 8335
      #47
      Originally posted by Kris Flynn
      it can run into speeds of 60MPH + with ease. Not that our P-Spec setups will get anywhere near that anytime soon
      Hehehehe.... my last years setup was clocked up around 53 (EagleTree airspeed sensor)... and Brian's VS-1 and Greg's Cobra are both faster than that boat... :D FUN, FUN!!
      Darin E. Jordan - Renton, WA
      • Kris Flynn
        #2 Bench Racer
        • 229
        #48
        I meant to put a ( i will add that and re-phrase now) at the end of that LOL
        • Darin Jordan
          • 8335
          #49
          Kris... You pretty much totally ROCK, as far as I'm concerned... something tells me you either have, or will soon be, breaking the 60mph mark with your P-Limited setups!
          • bigwaveohs
            • May 2009
            • 535
            #50
            Originally posted by Greg Schweers
            When I did run the VS1, the CG was 8", and I ran the stub shaft at 3/16 above the sponson. The prop I like best is the ABC 42x55, backcut, detongued and the tips rounded. I now run the Cobra - for the money, you can't beat this boat and they're cheaper than a VS1. If you do order one, order it without the radio box (the box that comes with it won't work), and it'll save you $20.
            I tried as you suggested and the boat flew at too high an angle and was diffcult to control in the corners...went back to 1/16" above sponsons and near zero stub shaft angle and it settled right down...corners at WOT.
            I let the dogs out...
