re post #1 Nicads will deliver less voltage as they are used, a slow spiral down ( a slide) whereas a NiMh will run virtually the same voltage for a time and drop off real quick ( a cliff). With the setup you have, I would try a 3s lippo with the largest MaH you can afford. You would still be under the 12 volt limit of the motor and hopefully the ESC and have way more punch for a lot less money and hassle than switching to brushless. Disclaimer: IMO!
Batt question
One more thought, well two. If you are happy with the speed of the 8.4 fully charged NiCd, I find that a 7.4 Lippo is better, not sure why, maybe less weight or just the voltage dump you get. It's a cabin cruiser and a big one at that and you don't want to dump the sunbathing babes of the bow! If you have enough room between the motor and floor, some cooling coils would be nice as well as brush cooling with a transom mounted Traxxas water pickup and it looks as though the prop is submerged and will help circulation. Who makes this boat? I like it!Comment
Hi Tony.
Here's one from HiModel. No BEC & no water cooling .
HiModel FLY Seires 70A Brushless Speed Control for boats W/Reverse function Type NAVY FLY-70-OPTO from manufacturer HiModel, in category Brushless Speed Control (BL ESC) - Boats, Electric Speed Control (ESC).
But I Agree with bwells. A 7.4 Lipo in this situation will be better than the existing NiCd. Two in parallel would hold up the voltage better & give a good run time. Watch the heat.
Scale models that I used to run on 12 cells also run better on 3s Lipo.
As bwells suggests a 3s pack will give good performance in this boat.
The only thing is that a lipo cutout is going to be required & the usual suspects from Dimension Engineering will not work on a reversing brushed ESC.
Novak however make one that does. I use one but I can't find the model number to give you. If You don't get one just keep an eye on the voltage of the pack & if it gets down to say 3.7V -3.8V per cell unloaded, call it quits.
All the best.
Paul.See the danger. THEN DO IT ANYWAY!!!
http://forums.offshoreelectrics.com/...hp?albumid=320Comment
Hi Tony.
All the best.
Paul.
I have 2s, and 3s lipos i can use. I also have a LipoShield LV cutoff. I think it would work like the Novak right?Comment
I have a 3s1p 5000mAh which i could use with the brushed setup. What do you mean hopefully the esc?Comment
If, you are happy with the scale speed just put in LIPO 2S batteries with a higher mah than your current 8.4v 1300mah NiCd batteries and use a Graupner brushed motor with an ESC designed for scale boats. Which can be run at low speed/voltages with brushed motors. You may wish to get on a site or hobby shop that has scale boat experience
DouggieComment
Both the LipoShield & the CellShield from Dimension Engineering are for 'Forward only' ESCs. With reversing ESCs they can lock them into full revs forward when you hit reverse. Not good on any day ending in the letter Y.
Here's a link to the Novak one. A lot of scale boaters use them. Me included.
As Douggie & others have suggested, run the boat on a 2s pack. You should get at least 20mins run time from a 5000mah pack with such a small load. But check the voltage regularly .
This will be your cheapest upgrade. Then try a 3s pack for comparison, but I think it may be well above scale speed.
All the best.
PaulSee the danger. THEN DO IT ANYWAY!!!
