Does NiMh batt run times longer than NiCd batt? I have this scale boat which runs on a 8.4v 1300mah NiCd batt. Run time is around 5 min. I also have a bunch of 7.4v 1500mah NiCd batts... Should i run these batt in parallel to get a longer running time? Or, just get some new NiMh batts? I also have some 2s 7.4 lipos, but don't know if it will work with brushed motor or not.
Batt question
Tony, it comes down to voltage and amperage. More volts, possibly more power, higher amperage, a longer run time. Yes, use the LI-PO based on the voltage specs for the motor?
Douggie -
motor does not have a name, direct drive.Comment
Great looking boat, change out the motor, and you are set to go with LI-PO. Some guys will chime in for a motor choice for that hull...I think
DouggieComment
Attached FilesComment
Hi Tony,
nihm batteries are better than nicad. If you assume the volts and amps are equal, nicad are older technology, and have a memory effect. That means that they need to be fully discharged, and fully charged, to be used at their best. Nimh have no memory effect, so can be part charged, and chaged again. As they are later technology, the amps can be higher. If you wire up to double the amps, and keep the volts the same, you will achieve better run times, however, if one of the packs is weaker than the other, the weak one will fail, and the good one will end up feeding the bad one!. If you wire to double the volts, and leave the amps the same, you will get more speed, if the motor and esc can handle the volts, it will be way more fun! but less run time.
The lipo battery is the next generation, more efficient, more power, but need a dedicated lipo charger, preferably a balance charger to monitor the cells, and preferably run with a low voltage monitor, these cost pennies, and plug into the balance lead, as you MUST NOT overdischarge a lipo.
Lipos can be used with a brushed motor, as you have the batteries, its worth experimenting, but if the nicad is an old one is probably ready for the bin!
If you want to go brushless, you also need a different motor mount, and another esc, and reversing ones are a bit expensive, so its down to budget. Depending what performance you want, I would be tempted to get a graupner 700bb turbobrushed motor, another mount for it to fit, make sure your esc is up to the job, then you can experiment with different batteries. If you want brushless, then maybe the racing guys can advise, I was going to fit a feigao 10turn xl into my 4 foot scale boat, but I think your boat would be too light for this set up?
Hope that helps!Comment
No problem running lipos with a brushed motor. Just follow the battery specs the instructions call for. VOLTS are VOLTS regardless of the battery chemistry.Mini Cat Racing USA
Hope that helps!
Laddy here is my reply
Another point of view
Rubbish, the Scotsman
DouggieLast edited by Flying Scotsman; 10-21-2009, 06:02 PM.Comment
Hi Tony,
Hope that helps!
I think a 380 brushless will fit in this one. But, i have to find an esc with a reverse...
This guy on youtube has one with a brushless.
Hope that helps!
DouggieComment
Hi Tony, I know what you mean regarding scale speed, its a nice looking boat, and the point I was trying to make (dont really know what douggie means by his response?) if you get it going too fast, it will be unmanageable and unstable, that hull could be difficult to turn, its certainly taller than a racing boat hull. I have a 3 foot scale boat, that is going way over scale speed on a brushed setup, and its very difficult to turn unless you slow right down, the profile of the hull rolls a lot!
A friend of mine has 2 mystery brushless esc's in a twin screw scale boat, they are on fleabay, (and quite cheap) might be worth a try with the brushless motor you have, and they are reversing.
You might need a programme card to set it up, we had to change all the factory settings to have soft start, and soft reverse etc . Also make sure that the esc will do fiorward AND reverse, there are a few out there on the net that are a little misleading with the description, forward, OR reverse (naughty!) if unsure mail the seller for confirmation!
Best of luckComment
Here's a couple of reasonably priced reversing ESCs. Watercooled & with BEC.
Haven't tried them myself but I have got other Turborix gear that works just Fine.
I have also burnt an older Turborix reversing ESC (older model) but that was totaly my fault.
Cheers.
Paul.See the danger. THEN DO IT ANYWAY!!!
http://forums.offshoreelectrics.com/...hp?albumid=320Comment
Cheers.
Paul.Comment
