kb 45 xl motors
  • Steven Vaccaro
    • 8723
    kb 45 xl motors
    We have a nice stock of the kb45 xl can motors and water jackets in stock.
    http://www.offshoreelectrics.com/products.php?cat=42
    We are trying to rig the site to give a discount automatically if a jacket is purchased with a motor. I hope to have that done by the end of this week. Until than if you buy a jacket and motor on the same order, I will refund $11 from the purchase.
  • saleens7
    • 1108
    • Rex R
      • 992
      if a 700 will work with the mount, you're all set (700's are 45-46mm in dia)
      • saleens7
        • 1108
        ok then...ill just need to find a 6mm to .187 coupler....or maybe have someone bore out a 5mm coupler to 6mm.....
        • ReddyWatts
          • 1711
          I have been waiting on these. Ordered the KB45 10XL and water jacket. Going to try it on 24 cells in the M1 Supercat.
          Did you say you were getting these with 5mm shafts?
          What is the maximum efficiency rating for each motor (amps)?
          Is there a spec sheet so that we can load these motors in FE Calc?
          ReddyWatts fleet photo
          • hammertime
            • 513
            steven i ordered a 8xl and wanted a jacket but it said out of stock
            60% of the time... it works every time!
            • SJFE
              • 4735
              Steven what size coupler do we use? What kid of stock do you have on the 8XL? I am thinking it would be perfect for the jolly. I would be able to turn bigger props. 19.2 volts @ 1700kv will give me 32640 rpms..just about perfect.
              • Steven Vaccaro
                • 8723
                Originally posted by saleens7
                i might get the 1200KV one as an upgrade motor for the SW36....will it work with this motor mount though?
                http://www.offshoreelectrics.com/pro...?prod=cen-bj16
                Hole spacing is a bit larger, you would have to file the 700 holes a bit to get it to fit.
                • Steven Vaccaro
                  • 8723
                  Any specs I have are listed on the site. Not much info is availible on these.
                  If you click the motor picture on the site, it will pull up a larger details page with what I have.
                  They are 6mm. They messed up my order and sent 6mm.
                  • Steven Vaccaro
                    • 8723
                    This is the jacket that kits the kb45 motor.
                    http://www.offshoreelectrics.com/pro...od=kb-45jacket
                    I have plenty in stock.
                    • Steven Vaccaro
                      • 8723
                      6mm couplers. I have some coming this week.
                      • SJFE
                        • 4735
                        Ok...I just realized somthing. I run a wire drive...What do you think we can do about that?
                        • SJFE
                          • 4735
                          I am going to just attempt to drill out the oem coupler I guess.
                          • part time
                            • 154
                            Tom take the oem one to a machine shop and tell them u need one just like it with a 6mm hole. then u will have both if u dont like the new motor.
                            • FE_Chris
                              • Jun 2007
                              • 764
                              So whats the cell limit on these bad rascals? 30 cells?
                              I am real curious about these motors. I wonder what kind of speeds that M1 superkat will see on 24-30 cells.......Hmmmmmm
