Utilizing Amonium Nitrate and water should cool things down a bit.
ESC Cooling Concept- Theory and Practice
One reason I think a pump is key to consistant flow. Sometimes, depending on turning, the water is not picking up as well. Full flow seems like it would be better to cool prior to a run and then after as well.
If you can guide me to any pumps I can sure try it easy enough. That and a cheapo fuel tank for nitro. My wondering is about how long the water will stay under 60 degrees. 4 minutes? 10 minutes? If the motor stays cooler to begin with then it will keep water from getting hot longer. If that makes sense.
6v should be fine to slow it down. Most rc fuel pumps will run on both 6 and 12v and are $12.Comment
Boat Components Water Test Fixture
After preliminary bench testing of various ESC cooling systems my plan was to evaluate performance for the various systems mounted in my Mean Machine with Eagle Tree data logging. However, I knew there would be lots and lots of testing with many environmental factors varying by a day to day. Any change or new system evaluation would take quite a bit of time to install in the Mean Machine, etc.
In an attempt to save testing time and make the evaluation boat and environmental conditions independent I developed a simple but effective water test stand. I wanted the ability to evaluate motors, props, ESC’s, data acquisition systems and even shaft drives using a convenient test bed fixture. Even the evaluation of the various ESC cooling systems could be evaluated under much more accurate and controllable conditions. This includes not being affected by daily ambient and water temperature changes. In addition, I could accurately monitor and control the water-cooling flow rate, something impossible to due using my Mean Machine since the water flow rate from the rudder pick up is speed dependent.
I have included a number of pictures of the test set up in my workshop. You can also see how the Eagle Tree data is displayed on the large monitor as well as recorded. I record all motor parameters plus three thernistors in-line with the water flow but not restricting the flow.
The motor is mounted to the top of the aluminum box section is a 540XL with a water-cooling jacket. It is coupled through a straight wire shaft that rotates inside a brass stuffing tube. This is sealed by two Hyco fittings so it can easily be removed and replaces with larger or smaller drive shafts. The props are also easy to change since the top waterproof lid is secured by four knobs. Attached to the motor is one of many different types of ESC’s to be evaluated. The large mass of wires are Eagle Tree sensors. To the right on the housing is my small water pump with inlet to by “Busty” water supply and output to the ESC and motor via the thermistor “T” fittings.
I have taken the lid off the test fixture and provided a close up picture of the motor and drive assembly. I built a bunch of different aluminum box sections so a wide variety of inrunner and outrunner motors could be evaluated.
You will notice in one of the final pictures that the liquid in the test tank is blue. Naturally you have to add a bit of “Tidy Bowl” to minimize cavitation bacteria, shaft fungus and propeller decay. (Just kidding, a few drops of blue food coloring added for show)
I have not put in a way to measure force or thrust at this time. There are a few ways to do it but that is Phase 2 of the project. Now it is time to start evaluating ways to best reduce ESC temperatures. Comments and suggestions welcomed.Comment
Joe, I'm glad to see you testing this idea.
Here are a few comments I have while moving forward:
1. Keep in mind that it may be advantageous to consider instant ice pack materials used for military field medical care. I'm not 100% familiar of the process, but it may be that you could incorporate controlled agitation (via vibration) to start and sustain cooling.
2. There is a product out there called Burn Gel that the military uses for severe burns. If I remember correctly, they had some concerns due to the high conductivity of the gel. It may be that the material would be a good, stable medium to use in the final design. The company that manufactures this stuff is H&H Associates and they also market the Cinchtight product. I'll see what I can do about going through my contacts of years past as I've known the owners for some time now. If I manage to get my hands on some, I'll send it to you.
Last, I have a question. At what point is this going to turn into a full blown condenser and maybe complete with an evaporator? I've often thought about controlled release CO2 canisters, utilizing the cooling generated as the compressed air escapes.
Just some thoughts and ideas. I'm looking forward to seeing the progress as this moves along.IMPBA: 7-Time FE World Record Holder "Don't think outside the box. Rather, refuse to admit that the box exists in the first place!"
Peltier Cooling Device Test Results
Several current threads in this forum mention the potential use of Peltier devices for ESC cooling on FE boats. I thought it was time to investigate this a bit further with some actual lab testing and real numbers.
The pictures attached show the details of my Peltier testing set up. On the desk is the Peltier thermoelectric cooling unit and large aluminum heat sink. Nest to it is the control board. It is powered by a 3S LiPo pack providing about 12 vdc. A V-3 Eagle Tree data logger with three temperature probes round out the test configuration.
The real-time data on the LCD monitor shows the three thermocouple temperatures both in gauge and numeric digital formats. The temperatures are ambient, around 77 degrees F, cold temp from the top of the Peltier device, T1= 57.4 and the temperature of the large aluminum heat sink, T2=119.1 and ambient air temperature T3=78. The LiPo pack voltage was 12.51
System specifications;
The unit I tested was one I purchased over 10 years ago at surplus. It was designed for provide the transport of temperature sensitive medicines on aircraft during long flights. Ice melted and was unreliable, Dry ice was hard to get, but the Peltier with a good battery pack worked out just fine.
The aluminum unit shown in the close up photo weighs 1 lb 9 oz or 704 grams. It is about 5”x5”x3”. The circuit board next to it is 2 oz or 60 grams: about 2”x5”x0.5”. The circuit board permits cooling adjustment by a slide switch, ability to turn the unit on at a certain temperature and auto fan control to take spread the heat or cold around. I checked the respective voltages and think the unit can work at max cooling without the circuit board. The temp set features are not necessary for a FE application I believe. The unit does draw 4 amps at 12 vdc that represents around 50 watts of power.
The top Peltier cooling plate is the solid, almost cubic piece of aluminum on the top of the large aluminum heat sink. This is the “Meat” of the device and measures only about 3”x3”x1.5”. It absolutely does need a heat sink to work….BUT that heat sink could be a finned aluminum box section that holds your LiPo batteries and keeps them nice and warm for optimum performance. The ESC could then be mounted on the top of the Peltier block and snuggled down by the two bolts attached.
Does this have merit if a FE…………………. What do you think?Comment
Your CO2 idea is one that I have already been playing with. I would consider getting the CO2 from dry ice. If you ever tried to put water in a bottle then add a bit of dry ice and put on a cork? Fire in the Hole! It is dangerous to do but if you use caution you will be impressed with the temendous amount of pressure released.
The system I am considering adds a controlled amount of misting water to some dry ice in a copper container next to the ESC. The CO2 generated would provide good flow and eliminate the need for any additional pumps, batteries. Let the expending gas do the work including helping with the cooling. The system would have to be designed with a high degree of safety in mind. It is one thing to crash and sink a FE but quite another to have it blown up by a CO2 bomb!
Now, your mission is simply to come up with that safe, workable solution!Comment
I would like to know if you cool the Peltier with our regular water cooliong if it indeed takes the coolness lower as well.
Also, I think the newer petiers may be a bit better but can't say for sure.
So how long would a 3S 1500 mah lipo last on that pletier?
Good stuff....I'm think you need to change your name to Dr FE!
I also found a pump that is small, I have not given up on the ice water idea but was impressed with the ice pack with so little in it to drop 20 degrees.Comment
Remember this used, surplus unit I have probably cost me less than $10 years ago. I have not done any research on current devices but that may be worthwhile. I certainly agree with you that there has probably been a terrific performance imporvement.
Also, I was thinking of removing the large aluminum heat sink on the unit I tested. I would replace it with a high capacity cooling plate and fan from some large quad-core computer processing chip. I bought a few of them for about $4 each.........but again they were surplus but new.
Your 3 cell Lipo is 1.5 amps and the unit I have runs at 4 amps. So, as a veryrough rule of thumb 1.5/4 = 0.375 hours or about 20 minutes.
As far as Dr. FE...........Thanks for the kind thought but there are probably at least several hundred guys on this forum that deserve it FAR more that me!Comment
But the peltier begins cooling very quickly, yes?
20 minutes is good if a person can rotate the cells between heats. Just not sure it is worth it but for the big boats with room and long runtimes for racing. I would think anything would be better.
Keep up the good work. I am still on the cold water circulation idea but need something to work with in a real system . I have to stop by the hobby shop and get a fuel pump that works on 6v or 12 which draws next to nothing for power.Comment
Jeff, Why not a small fishtank pump? You can get very small ones fairly inexpensive and many of them run on 12v, very little power consumption.
Joe, regarding the blue ice, I was actually referring to a product the military uses where static, it is the same temperature as the environment. Then when agitated, a chemical reaction occurs where the pack safely drops temperature using biodegradable safe components that, even if exposed to a wound, are safe for contact and environment. => Instant ice pack. I'll see if I can find a link.IMPBA: 7-Time FE World Record Holder "Don't think outside the box. Rather, refuse to admit that the box exists in the first place!"
Most fish pumps I find were air not water but I will look. I found a very small round one that weighs nothing and only $12.
I also want a 6v for slow flow and then just a small pack of 2s would run it for a long time and actually bump it up a bit with flow.
My thought is why not be able to begin cooling prior to running. We used to do that with brushed and it made a big difference.
I remember people putting pumps in the cooler with water and hooking to the cooling system and circulating. Mags do much better at cool temps.Comment
After reading so much this morning, I will now always use copper to make my ESC cooling plates. Also, there are many cooling fluids that can be used and much better than water. Now I might be able to use the little ice cubes Steven had so not to taint the fluid yet chill it.
PC fluid cooling CPUs is easy to find and good stuff.Comment
