ESC Cooling Concept- Theory and Practice
  • questtek
    • May 2009
    • 556
    I thought a new thread may be appropriate in response to the “Cooling Brain Fart” thread to discuss a bit of theory, few facts and present one potential workable concept for cooling ESC’s for FE boats.
    The Theory….
    ESC’s use conduction cooling. (so do electric motors but lets focus on ESC’s) The better the conductive path, the better the cooling. For aircraft ESC’s the high velocity wind from the prop across the finned heat sink is normally sufficient. In FE boats, the normal air cooling is not adequate which is why marine ESC’s are water cooled and/or forced air cooled by using a small brushless fan similar to that cooling a computer processing chip. Excessive heat is probably one of the major causes of ESC’s burning up in FE boats.
    To improve cooling in an attempt to burn out fewer ESC’s we need to improve conduction cooling. This means using better “heat sink” materials to convect the heat away, increasing the surface area of the conductive “heat sink” and reducing the inlet cooling water temperature. Getting heat out of the FET’s is the goal.
    In terms of better heat sink materials one needs to look at the thermal conductivity of the material used. Thermal conductivity is the quantity of heat transmitted through a unit thickness of material due to a unit temperature differential. (The term “unit” means that we care compare apples-to-apples so to speak). Maybe a simpler definition would be the rate at which heat is transferred by conduction when a temperature gradient exists. Simply put, the higher the thermal conductivity of a material the better it cools.
    Comparing thermal conductivity of different materials………..
    Silver has one of the highest thermal coefficients at 429 but copper is a close second at 400, (and a lot less expensive). Aluminum is 250 and Brass is 109. Since conductive heat transfer is directly proportional to the thermal coefficient, use of copper rather than aluminum for a heat sink would provide a 38% improvement. Can you imagine running aluminum wire from your ESC to LiPo’s and brushless motor? The building code for many areas now requires use of copper wiring and not the cheaper aluminum wiring (as in my 27 year old home).
    Several great threads have been submitted on adding cooling to ESC’s such as the relatively inexpensive 200 amp Mystery models. Brass tubing is integrated into the existing aluminum heat sink. But the thermal coefficient of brass is 109 compared to 400 for copper. I think you can work the math here for the best tubing material.
    A proposed open loop cooling concept ……………
    In a previous thread I outlined using a 35 mm film can or canister with a cooling coil inside. The canister is filled with water than put into the freezer. The inlet water passes through this prior to going to the ESC and motor. Even this simple idea decreases the film canister outlet temperature but about 20 degrees. However I only use this on very small boats in the 12-16 inch range. It certainly would not help to any degree of most of the larger FE’s that are run by members of this forum. One comment I saw in the forum recommended just using water or alcohol in the canister (or really the cooling tank). Is this good idea? All one has to do is to compare the thermal coefficients…. remember the higher the coefficient the better the cooling. Air is 0.024, water is 0.58, alcohol is 0.17 and ice wins out at 2.18. Thus the cooling with all ice is 4 times as effective as water at the same temperature. The large ice value is a result of the latent heat of melting….if that makes any sense. (I am running some tests on the liquid used in ice packs and will post the results later.)
    One Concept for “Canister Cooling” that I use on my Mean Machine with a 540 XL….
    For lots of cooling we need lots of copper tubing. In the pictures you can see I purchased some small Tupperware-type containers: 4 for 99cents and the……….you guessed it, the local 99-cent store. I wound 20 inches of ¼ inch diameter copper tubing around a wooden plug so it fit perfectly in my 25-cent container. If you calculate the surface area of this length of tubing it is whopping 15.7 square inches. (Compare this to the aluminum heat sink that comes on many ESC’s) The entire cooling unit weighs 3.7 oz or 104 grams and when filled with water (ice) it weighs 6.2 oz or 176 grams. The dimensions are 3” x 2.3” x 2.4” high. (pics included)
    Now for a canister cooling comparison:
    1. My 35 mm film can with brass tubing has an effective total cooling number of 513. (You get this by taking into account material used as well as diameter and length of tubing)
    3. My 25-cent Tupperware-type container with 20 inches of copper tubing has an effective total cooling number of 6,280. Enough said on this.
    How well does this really work?…………….
    Good question and that is what I am determining now. I use an Eagle Tree data logger that has 3 temperature probes (thermistors). One is on the ESC, one is the inlet water (for the fresh water lake in front of my house that is about 76 degrees F now), and the third is the water temperature on exit from the cooling canister. (pics included) Stay tune for the results.
    I am sorry for this thread being so long but I wanted to create a common technical base so the different ideas and cooling gadgets from forum members can be numerically compared….apples-to-apples. As a teaser I think there is a MUCH better way to provide ESC cooling that does not require canister cooling, Peltier plates, fans, pumps or giant heat sinks. I have modified an idea used by the Russians in their MIR submersibles that have gone to the bottom of the North Pole and made over 100 trips to the Titanic. Again, stay tuned for the results……..IF I can make this concept work!
    I look forward to your comments and suggestions
  • Steven Vaccaro
    • 8721
    Until this is tried and tested, I'm moving it to the, questions and answers area. Since its theory and not a "how to" yet.
    I like your idea, one thing to think about. The system needs to be blown out after each run, so you don't have frozen water inside the copper tubing.
    • Jeff Wohlt
      • Jan 2008
      • 2716
      Good info. I was surprised the # differences in alum to copper. I was surprised to see brass so low.
      I do not see why it won't work. I saw those tuperware boxes at walmart but thought they were a little big. I am also looking at small tanks or vac forming something that would be thin and then put the coil in and seal it shut....the inlet/outlet would also be formed at the same time and then just epoxy it shut.
      I would try the coil in the boat without anything else and run it just to see how flow is from the rudder. I would think it would be fine.
      www.rcraceboat.com
      [email protected]
      • Drag Boat Bob
        • Apr 2009
        • 304
        Great information! Keep up the testing.
        This is a take on an old time car drag racing idea where dry ice was used in a canister to cool down the fuel prior to entering the engine.
        With all of the ESC failures (many due to heat) out there, any new idea would be great IMO.
        • DISAR
          • Aug 2007
          • 1072
          Nice work!
          Your theory is correct. Your water inlet temperature will be probably lower resulting in a lower ESC temp. How about the actual ESC cooling, what wil be the arrangement? Which ESC you will test? In order to have good results you should use a marginal ESC for your setup.
          Are you going to measure the temperatures with and without the canister?
          http://www.rcfastboats.com/
          • questtek
            • May 2009
            • 556
            Originally posted by DISAR
            Nice work!
            I will post some pictures later of the test set-up and how I have tied the three temperature sensors into the cooling system and the Eagle Tree logger. I should also be posting some test results later today.
            Totally agree on using marginal ESC's I have ordered 4 Mystery ESC's
            1. 2 of the 100A units (2-6 LiPos)
            2. 2 of the 200A units (2-4 LiPos)
            The total cost for everything was $95.96, a great deal for experimenting.....IF they ever show up!
            I will measure the temps with and without the canister. First on a bench set up then in the blue Mean Machine in the pics. It uses a 540 XL and a 4 cell, 5000mAh, 40 C pacs. Testing is easy since I live on a lake and have a 16 foot electric boat to "pick up the pieces".
            • questtek
              • May 2009
              • 556
              You might want to try your local 99-cent store...they have several different types of small "tupperware-type" containers. Remember, it does not have to be large. The small plastic box I am using is only 3x2x1.4 or about 8.4 cubic inches in volume. They have another box that is retangular 2.5x2.5x1.5 high or 9.3 cubic inches. The retangular box rould permit winding the copper cooling tube around a section of old PVC pipe. Remember, this copper tubing represents the same area as a 15.7 square inch heat sink made out of a material that is roughly 4 times better heat conductor than aluminum.
              I have included a picture of the copper cooling tube in the rectangular "Tupperware" box. It is 24 inches long, about 17% larger than in the slightly smaller rectangular box. I must admit it is easier to wind a round coil. In this case I used a 1.75" OUTER diameter PVC pipe as shown in the picture.
              I also included a pic of the EagleTree system Note the three thermistors; I built them into 'T" fittings and sealed the thermistors. This does not restrict flow since the thermister tips are just at the endg of the main flow. With these I measure inlet (black shrink tubing on end) and outlet (red shrink tubing on end) and the final thermister is on the ESC itself.
              • Jeff Wohlt
                • Jan 2008
                • 2716
                Excellent. Will you do cold water in the box or or the gel? I have an idea I will share later this evening...and something to show.
                www.rcraceboat.com
                [email protected]
                • questtek
                  • May 2009
                  • 556
                  You might want to consider tight fitting rubber gromets for sealing. Add a bit of silicon if you want. In the picture shown I connected the white silicon cooling lines to the copper tube INSIDE the tupperware housing. The silicon tubes exit the housing through tight rubber gromets. I think this is easier and works much better becasue the flexible tubing gives you lots of options for the outlet and inlet.
                  You asked about just using a copper coil along. Actually this may HURT you rather than help you. The amount of heat transfer is proportional to both the thermal coefficient of the material as well as the temperature difference. With ice that difference is inlet lake water temperature minus the ice temp which is about 32 degrees F.
                  If you just use the copper tube inside the hull there is a chance that the internal heat from the ESC and motor..............and expecially if you warm your LiPos, may cause the copper to heat up. In this case you would be ADDING heat to the ESC and motor rather than revmoving it.
                  • questtek
                    • May 2009
                    • 556
                    I look forward to hearing your idea. Good luck on the testing.
                    I am experimenting with both the ice and the gel. I could not find the thermal coefficient for the gel but I continue to search for it. I will just test both of them and see what happens. My guess is the gel will show a degree of improvement over plain water.
                    Remember, cold water has a thermal coefficient of 0.58 and ice is 2.18. Putting the box in the freezer to form ice is a tremendous improvement in cooling efficiency. Even if you use the gel, freez it!
                    • questtek
                      • May 2009
                      • 556
                      I have just finished some preliminary tests. The pictures show the test set up.
                      The entire system includes the cooling system components including small 12 vdc pump to duplicate the water coming in from the boat's water intake. I have a large monitor to view the Eagle Tree data in the live mode plus also record it. I am measuring the three thermister temps, inlet, outlet and ambient. There is no ESC in the loop, I just wanted to see the temperature difference as ambient water cooled after passing through the copper tube in my tupperware ice both.
                      In the test set up, ambient water is in the red plastic cup, the small 12 vdc pump pulls the water out as it passes by the intake temp thermister.. The ambient water flows through the cooling container then into my High Fashon Drinking cup. The outlet tube has a thermistor attached.
                      The close up of the Eagle Tree temp guages, inlet and outlet pretty much tell the story. You can observe the temperature drop. I also noted the cooling started to decrease after a bit....the reason was the water was melting around the tubes previously covered by ice. and warming up) I just shook the tupperware cooling canister....to duplicate the vibration and movement on a FE and the temperature came down again. It appears you cannot have "stagnant" water next to the copper cooling tubes.
                      Now to try the gel then some real tests in my Mean Machine.
                      • Steven Vaccaro
                        • 8721
                        I dont see any of eagle tree pictures?
                        Also would it be better to have more space in between each coil layer? So there is more ice in between each coil?
                        • DISAR
                          • Aug 2007
                          • 1072
                          Pictures? How much is the temp.difference?
                          • Ken Haines
                            Racer
                            • Jul 2007
                            • 647
                            Great Work
                            You guys are doing great on this cooling R&D. I do not have anything to add, just wanted to let you know that I'm following this closely. My free time to field test this stuff may not be soon enough as you guys have really jumped all over this.
                            Maybe I can pledge that whatever is the best end result, I will race test at the 2010 FE Nats.
                            Keep up the great work!!!
                            Thanks, Ken
                            TenShock Brushless / Pro Marine
                            INSANE Boats / Rico Racing/ Castle Creations
                            2023, 2024 NAMBA & 2018 IMPBA FE High Points "National Champion"
                            • questtek
                              • May 2009
                              • 556
                              Sorry, the pictures must have gone to electronic vapor-land but they should now show up below.
                              You are correct on coil spacing...you want the ice or gel surrounding each tube so a bit of open space is best.
                              While this method appears to work quite well in the test setup, I still need lots moe testing to refine it. I need to come with the size of the container and coils as a function of duration of run and size of ESC and motor.
                              It has been over two weeks since I ordered my four 200 and 100 amp mystery controllers but they have not arrived for the real serious testing.
