Boat to play in the waves with
  • soulreaper
    • 58
    looks like it can be fun.
    • rockwerks
      • Jul 2008
      • 772
      Originally posted by crabstick
      i have one of these, made it brushless and lipo, it screams but the jet unit becomes unprimed quite easilly. Make sure u bush the jet unit with a bit of brass.
      my choice for the wave boat would have been a oval master 26, build a flood chamber and your done!
      Too big and cant turn as quick. also if it flips it has a chance to crash onto the many many rocks before it rights itself. ID hate to Screw up a nice hull like that. I ahve tons of RC bearings in hundreds of different sizes. They will be fully bearing supported soon
      an RC rock crawler lost in a sea of boat parts.........
      • westbeach
        OSE Rocks!
        • 951
        Rockwerks,
        Where can I find these NQD boats in WA? I am headed south across the border for the day, into Bellingham. Would like to pick a couple up if they are available locally. Thanks
        Originally posted by rockwerks
        Well the 2 high dollar boats showed up today. But with a major downpour happening probably wont get em wet till tomorrow
        abs hull of decent thickness nice driver and motor detail. uses 2 body posts to mount the hatch into a groove that empties to the rear of the boat
        the intake is going to need a little work
        the hull is totally sealed, Im gonna have to fix that!
        HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
        • rockwerks
          • Jul 2008
          • 772
          Unfortunately not I ordered them online.
          If there is anything I can do to help LMK
          • westbeach
            OSE Rocks!
            • 951
            Want to sell me of one your NDQ's??
            Thanks for the offer, I will keep it in mind, bud! Cheers
            Neal
            • westbeach
              OSE Rocks!
              • 951
              Rockwerk,
              BTW how thick do you figure the hull is? Do you think it needs reinforcing?? There is vids of one launching off logs or something like that over at RCU.
              • rockwerks
                • Jul 2008
                • 772
                Originally posted by westbeach
                Rockwerk,
                Its fairly thick and and flexible. it should hold up fairly well. I dont think Im going to reinforce it just yet but I am looking for a cheap esc motor combo to fit in already.
                • crabstick
                  • Jul 2008
                  • 954
                  #23
                  Funily enough, I own both, the OM for me is better mine has a flood chamber, when setup it rights in about 3-4 seconds, but i dont have to avoid rocks like you. Hope the jetboat works out for you.
                  Matt.
                  FE, Nitro and Gas racing in Auckland
                  www.rcboats.co.nz
                  • rockwerks
                    • Jul 2008
                    • 772
                    #24
                    I saw your rig on RCU the BBY 26 nicely done. Im hoping to be able to get this little boat to surf the waves as they come in. MY wife is excited about these too.
                    • westbeach
                      OSE Rocks!
                      • 951
                      #25
                      rockwerks,
                      Have you looked at the Aquacraft UL1 motor/esc combo? I was also thinking about the Scorpion Outrunner series. Might be a little more than a cheap setup. But they are reasonably priced.
                      • rockwerks
                        • Jul 2008
                        • 772
                        #26
                        rockwerks,
                        These boats are small. 17" in length and light! they use a 380 size motor with 2.3mm shaft. Im actually looking at a 3700KV 180L and already have a few small esc's lying around.
                        • crabstick
                          • Jul 2008
                          • 954
                          #27
                          with the jetboat instead of making a coupler, make a new slightly longer shaft, and get an outrunner that uses a 2.3mm shaft, extend the driveshaft through the outrunner, no need for a coupler then or any alignment issues.
                          other thing I found when building my jetboat is the impeller will slip on the driveshaft very easily, i simply drilled a hole in the impellor and tapped a 3mm thread into it and ground a small flat on the shaft and loctited it.
                          with my setup I run a 3500kv outrunner from my trex450 heli, hyperion titan 30amp esc and 2200mah 20c 3s lipo
                          Matt.
                          www.rcboats.co.nz
                          • Ctonez
                            • Jul 2007
                            • 404
                            #28
                            Okay, you guys are getting me thinking about jet boats and watching every youtube NQD video I can find...
                            RCU had a great jetboat thread started by Quicksilver a couple years back. He did a jet conversion to a Traxxas Villain that was really inspiring. One innovation he did that I thought was brilliant was a thick strip of aluminum(?) along the keel both to support his own intake, and allow him to bash it like a fricken Rock-Crawler over rocks, docks, logs or whatever. He had vids of it launching off of a half sunken dock that were straight-up incredible...I'll see if i can find it.
                            • Ctonez
                              • Jul 2007
                              • 404
                              #29
                              the thread: http://www.rcuniverse.com/forum/m_6523863/tm.htm
                              you've likely seen it already...the boat in Quicksilver's avatar is the one I remember.
                              There are links to his vids and his original build in the first few posts. I learned a ton from his experiments and have always had plans to build a river basher of my own someday since following his threads.
                              • Rumdog
                                • 6453
                                #30
                                i would suggest a 400 df outrunner like used in the renegade rigger. Un-cooled it rips on 3s. 2600 kv or 3300. Great little motors!
