Is there a correct rotation for a prop?
  • rcflysal
    • May 2009
    • 8
    Hi:
    on a mean machine with a Fiego 9XL and an Octura X642 prop, Looking from the back of a boat which way should the prop rotate, clockwise or counter clockwise? Knowing that by changing two wires you can change rotation of the motor, I get confused?
    Thanks
    Sal B.
  • Boatman
    • Jan 2008
    • 796
    counter
    • Ub Hauled
      • Aug 2007
      • 3031
      counter if you are driving clockwise and
      clockwise if you are driving counter-clockwise
      • rcflysal
        • May 2009
        • 8
        Prop shafts can be confusing
        Hi:
        I noticed that on the mean machine the prop shaft rotates counter clock wise and the prop nut holding the prop to the dog leg tightens clock wise which seems correct to me. This would help keep the prop nut tight.
        My friend has a Hobby Lobby off shore catarmaran with a brushless motor and an X442 prop and his prop nut tightens count clock wise and the prop spins clock wise which helps keep the prop nut tight.
        The prop don't care which rotation it spins?
        so confused???
        Sal B.
        • Ub Hauled
          • Aug 2007
          • 3031
          well, the flex shaft has to be the appropriate thread for each different rotation, otherwise, on top of may losing your prop you will fill the hull with water too.
          • JimClark
            • 5907
            the thread are the same but there are right and left hand flex cable
            Billy Graham
            • rcflysal
              • May 2009
              • 8
              The prop will push water left or right?
              Hi:
              It don't matter which way the prop is turning, both ways are effecient? Both these boats I looked at have similar looking Octura props, just a different size, yet one turns clock wise and the other boat it turns counter clock wise and thias is OK?
              Thanks
              Sal B.
              • Flying Scotsman
                Fast Electric Adict!
                • Jun 2007
                • 5190
                Originally posted by rcflysal
                Hi:
                Thanks
                Sal B.
                And what is your question, as it has been answered
                Douggie
                • rcflysal
                  • May 2009
                  • 8
                  yes, all questions have been answered.
                  Thanks for the quick responses, all my questions have been answered.
                    • 8012
                    What others seem to have missed here is that there are left-hand and right-handed props. If you look closely, your prop is "left-handed" and your friend's is "right-handed"; there is more difference than just the size. If you turn one the "wrong" way the boat will go backwards. So yes, it does matter which way the same prop turns - a lot. To go forwards it has to turn the correct direction.
                    R/C race boats almost always run clockwise courses because the prop helps the boat to turn....most all R/C props turn counterclockwise.
