What schultz-clone would that be?
Ajoda 200 amp esc?
I have one of those around somewhere. It's HUGE. Guess I'll dig it out and offer it up here.Mini Cat Racing USA
Ozzi :
That's why the Schulze-clone is by far the best !
Multi-layered esc's suck !!!
The majoda with pipes on EACH board is far better IMO , compared to the multi layered esc's with coolingplates on each layer.
Why cooling plastic housings if you can cool bare metal ???????
BTW : why do i see so many CC's burn up recently ????????????
to me it looks like it may have a plate running across the top board that then goes down each side with the tubes attached to each side
iam not 100% sure on this but i think the reason there is a lot of multi layered boards is the larger the fets the slower the switching speed, so they use many small fets (low amp) instead of just a few larger (higher amp) ones
as a lot of esc,s are made for helis or planes with high pole motors they need very fast switching fets
if iam rite in this then esc,s just made for 2-4 pole motors could have larger (higher amp) fets with lower switching speed therefore needing far less fets making the need for only a single layer boardComment
That's why I only use esc's that are designed for boats :-)
A few weeks ago I saw the prototype of the next esc from
"modellbauregler.de" , 2 guys who are so dedicated to our hobby !!!!
120 A cont. and so unbelieveble small !!!!!!!!!!!!!!
It really blew my mind, CC eat your hart out ;-)Comment
Of course there is always "The Beast" which touts 'no water cooling'.
If of course, it doesn't sink your boat at 450 grams.
With 48 FET's, 8 Rubicon caps and double 12 guage wire and cooling plates (air) on both sides, it truly is "The Beast".Attached FilesComment
unfortunately I have heard of these "Beasts" goingtoo
I will try and find the Thread, I too was looking into getting one of these for a 1/8 scale Hydro and I googled around and found a couple that had burnt.Comment
Several in this thread have Burnt.
Have you tried contacting them directly? http://www.suppomodel.com/Government Moto:
"Why fix it? Blame someone else for breaking it."Comment
