Bad day.Smoked esc, cracked motor
OK.
I have the MGM 25035 z-series and so far no problem. I definately agree to buy a good one from the start instead of messing around.Twin Cat 135, Sprintcat40 (single-twin), DF 35", Maritimo, Mean Machine, SV 27
http://www.rcfastboats.com/Comment
some informative videos here about using their products
Mini Cat Racing USA
This guy on Youtube is running with a NEU 1521 1y, prop M445, 6S2P. I''m wondering which esc he is running with. Check out the video.
This guy is running KB45 1200rpm, Turnigy 100amp HV. (I have a brand new Turnigy 100amp HV 2-12 Lipo , and Pistix)
There are E series, and Z series ESCs. I'm running either 6S1P or 6S2P sport run setup with atleast 50+ mph range. So which esc would work with Neu 1521 1.5y.
http://www.youtube.com/watch?v=Wr7KhR4Ixw0&NR=1
If you are running 6s for me it is better to have an ESC rated for 8s. Please read this (takes some time)
Do not believe what you see in youtube or even here sometimes. Maybe the setup runs great for 2-3 times and then takes video etc.. but when the damage happens in the next run nobody knows it.
The 1521 1.5 Y is 1050kv, on 22.2V , 23,000 rpm theoretical. Seem a bit low for the 50mph range. I do not know this hull very much maybe somebody will come in.Last edited by DISAR; 08-27-2009, 06:46 AM.Twin Cat 135, Sprintcat40 (single-twin), DF 35", Maritimo, Mean Machine, SV 27
Necessity is the mother of invention.............
Youtube Video's http://www.youtube.com/user/Titanis2000Comment
Found this in RRR, NEU 1521 1.5y, 8s2p, 442 Turnigy 100amp HV 2-12 Lipo . Better to contact him, if this setup is OK you can use your ESC and get the rest.
http://www.rumrunnerracing.com/fefor...light=maritimo
Thanks for the link.Comment
I have a cat that I had FDM assemble. After looking at your pics I took a look at mine.
The JB weld was starting to lift from the hull. So I sanded the whole area and took some epoxy and fiberglassed the whole thing down. Your mishap just prevented me from having one. Just wished you had of caught yours before this happened.Government Moto:
"Why fix it? Blame someone else for breaking it."Comment
The JB weld was starting to lift from the hull. So I sanded the whole area and took some epoxy and fiberglassed the whole thing down. Your mishap just prevented me from having one. Just wished you had of caught yours before this happened.Comment
Fine weave glass and 30 min epoxy. Feels real solid now. Tried pulling the mount. It's stuck in there real good now. I think if I tried to pull it out, I'd probably break the hull.Government Moto:
The JB Weld is probably good stuff in it's own right. What I suspect is the cause of the weld breaking away from the hull is zero preparation by the builder.
When epoxy resin cures there's a chemical (I can't remember the name) that rises to the surface & is sort of like a wax or sheen. This needs to be removed before over coating with more epoxy resin or adhesives. All that is required is a scotchbright pad & hot water. Make sure it is dried completely(hairdrier) before overcoating or glueing. I also then wipe it with a cloth dipped in acetone first.
I also do the same procedure with polyester resins too.
Cheers.
Paul.See the danger. THEN DO IT ANYWAY!!!
http://forums.offshoreelectrics.com/...hp?albumid=320Comment
If you want maximum adhesion with JBweld once its mixed and setting in the boat heat it with a hair drier to about 175 to 200 degree's . It turns to a watery consistancy and absorbs a lot better into the hull below . the bond will be way strongerNecessity is the mother of invention.............
