Outrigger websites
  • Ub Hauled
    • Aug 2007
    • 3031
    #106
    Originally posted by mr rumrunner hobbies
    I am little let down rumrunnerhobbies did not make the list we sell the most dominating electric spec rigger in namba the RAPTOR and almost as good jae fe both around 30 inches and capable of going over 60mph we are rigger people. Just thought some people would like to know doug
    Doug,
    send me a link where I can see the hull and it will be posted...
    this list was made so people have something "palpable" to have in mind when looking for a hull,
    I am sure there are a few more good riggers as well as not proven ones that have not been mentioned
    but only because I have not seen a link or at least a photo and a contact number.
    No discrimination intended...
    • sailr
      • Nov 2007
      • 6927
      #107
      Link doesn't work. 404 not found.
      Originally posted by Meniscus
      Jan, here's a real nice one for ya!!!
      Top Gun I
      Cells: 6 - 8 Cells
      Size: 680 mm x 410 mm
      Weight: 380-450 gram without Deko !!!!
      Mini Cat Racing USA
      www.minicatracingusa.com
      • mr rumrunner hobbies
        • 14
        #108
        Thanks for the reply i am not good on the computer the sight is rumrunnerhobbies.com and i dont know how to send links,see if you can help me out thanks doug
        • gizmo1
          • Dec 2010
          • 254
          #109
          here ya go Doug, this should work for you.
          Giz.
          JAE21 Rigger, ML Boatworks PS 295 Tunnel , TS3 FE Tunnel , H & M No Step 3 Mono , H & M Skater , Wildcat EP , Rio EP .
          • sailr
            • Nov 2007
            • 6927
            #110
            Here's the raptor
            Mini Cat Racing USA
            • Ub Hauled
              • Aug 2007
              • 3031
              #111
              Link fixed, BK had changed the site...
              • Ub Hauled
                • Aug 2007
                • 3031
                #112
                Doug, are you the exclusive distributor of the Raptor? I have Raptor Marine posted already... directly to Brian.
                  • 14
                  #113
                  Yes i am the only one selling the raptor ,they are about 80% built and nicely made,brian is a true craftsman,I have my raptor over 60 and thats fast! funny thing is that is with a ul1 motor cant wait to try a leapord.. doug
                  • Ub Hauled
                    • Aug 2007
                    • 3031
                    #114
                    Doug, it's done...
                    • knightmoto
                      • Nov 2010
                      • 17
                      #115
                      Hello all, Quick question, Building a Rigged Insanity, I am fabbing up the sponsons, After bonding I kept the bottom of the sponson flat or 90 degrees, It follows through to the tips, Now what I am concerned about is that other sponsons I have looked at taper at the ends. How critical is this area and will the ones I modified work? Only going in straight line so not to concerned about turning. Any suggestions? Or should I start over on these? This is my first Rigger build so its a test bed... Any feedback is greatly appreciated! and Happy New Year!!All!
                      • knightmoto
                        • Nov 2010
                        • 17
                        #116
                        One other question for those in the know... An HOLC Rigger? Hope I spelled that correctly, Where can I purchase one? And anyone no if the Mr. Crabs is a good hull? Thanks!
                        • Ub Hauled
                          • Aug 2007
                          • 3031
                          #117
                          Originally posted by knightmoto
                          .....the sponson flat or 90 degrees, It follows through to the tips, Now what I am concerned about is that other sponsons I have looked at taper at the ends.
                          Not sure if I understand what you mean by "taper at the ends".. .is it the leading edge or the trailing edge you are talking about?
                          The HOLC Rigger is not made anymore... there are a few floating around but the owners dont sell them often... I'd suggest starting a "WTB thread" to see if you can score one.
                          • knightmoto
                            • Nov 2010
                            • 17
                            #118
                            Hey Thanks UB, To best describe my sponson situation, If you take a square and place it on the inside and bottom of sponson (nearest to Tub) And slide it across from trailing edge to leading edge, Most are usually tapered and the leading edge, ( just slightly though) And mine in at a perfect 90 degrees from trailing to leading. Hope that makes it a little more clearer. Anyway just want to know if it will effect it in anyway. I am going to go with it for now and test it. If it handles funny I can easily replace them. But just wanted to ask and see if anyone else has fabbed them this way so I know what to expect. Thanks again for the info on the HOLC's. Until then...
                            • Ub Hauled
                              • Aug 2007
                              • 3031
                              #119
                              I see... there are different ways to build sponsons... a bit tapered will give you slightly less lift... how many degrees do you have the "ramp" at? For SAW runs, the "pros" suggest up to 4.5 degrees (FYI), off course it'll depend on a few other things...
                              • knightmoto
                                • Nov 2010
                                • 17
                                #120
                                Thanks UB, Its set up per print on the instructions so not sure the angle on the ramp. I'm doing my home work and research, So many variables...Can't wait to do some field testing, just got motor,stuffing box and strut mounted, So far so good! Today will do the rudder and servo set up. What are you guys using to coat the wood? I see no need for epoxy coating as no nitro, and heavy, light polyurethane coat ok? waddya suggest? JK
