Motor KV?
Thanks.
What about one of these motors?
That motor kV is too low for 2S or 3S"A quick temper will make a fool of you soon enough."
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Bruce Lee. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .Comment
What would be better for KV? because i have two 3s 2200 25c lipos that i run in parellel, and i have 2 2s 5000 20c lipos that i can run in series or parrellel. So what is better high or low KV? I would prefer to run the 2s in parellel to get 10000mah. Then ill have the 3s in parellel for just messing around.
So around what is a good KV for 2 and 3s?Comment
The 2880 kv motor it comes with would be OK (about max RPM for a mono) on 3S.
I would not run it on 4S.
It would also be OK as a Sport boat on 2S
LarryPast NAMBA- P Mono -1 Mile Race Record holder
Bump & Grind Racing Props -We Like Em Smooth & WetComment
with your 2s 5000 in series run either a ammo 2300 x440 prop see you around 45mph. if more speed is wanted try a 8xl x640 prop
This thread has a lot of good info. http://forums.offshoreelectrics.com/...read.php?t=271Government Moto:
"Why fix it? Blame someone else for breaking it."Comment
generally yes. i have seen a lot off people try and run these on high kv 380 or cheap 540s motors and usally all they do is pull high amps
i look at it this way the bigger xl motors can pull more amps but they have more power so they can spin the same size prop a lot easier so they dont pull more amps. my 25" mono runs a ammo 2300 on 4s with a x440 and i only run a 45amp esc. the esc and batteries you have should be enough for a 8xl
i would start with a x440 and go from there
Agreed. Someone once told me, a "S" motor should be considered like a 4 cyl. An "L" like a 6 cyl. and a "XL" like a 8 cyl. At least as far as the chinese 2 pole motors go. Take a look at post #19 in my previous post for general guidelines.Government Moto:
[quote]with your 2s 5000 in series run either a ammo 2300 x440 prop see you around 45mph. if more speed is wanted try a 8xl x640 prop [quote]
Well i got an 8xl coming my way, now what can i do for the prop situation? Because i beleive it is an 1/8 shaft. Can i just use a little shim? That way i can run the 3/16 x640Comment
[QUOTE=M.M.;102968][quote]with your 2s 5000 in series run either a ammo 2300 x440 prop see you around 45mph. if more speed is wanted try a 8xl x640 propYes. You can put a small piece of k&s tubing in the prop to shim it up http://www.offshoreelectrics.com/inf...propellers.php
Well i got an 8xl coming my way, now what can i do for the prop situation? Because i beleive it is an 1/8 shaft. Can i just use a little shim? That way i can run the 3/16 x640Government Moto:
