Using a Super Whatt Meter on a Boat?
  • TLH101
    • May 2016
    • 59
    Back when I flew electric R/C aircraft, we lived and died by the Astro Super Whatt meter.
    Is this a feasible tool for checking amp draw in an R/C boat set-up? Can I get an accurate reading with the boat powered up and held static?
  • photohoward1
    • 1609
    Not held static. There will be no load on the Motor.
    • TLH101
      • May 2016
      • 59
      I meant static in the water.
      • jkflow
        • Aug 2021
        • 329
        Could be done but this is a low Amp wattmeter, I believe it tops at 15A, barely usable. Maybe for a toy pool boat or for scale type boats.
        I assume it holds the max value that you can read after the fact.
        • TLH101
          • May 2016
          • 59
          This a 100 amp capacity.
          • Silver954
            • Feb 2016
            • 69
            The loads in boating can swing wildly. It will be easy to burn up this device, plus the extra resistance in connectors.
            Just an example, 1/8" in strut depth can be the difference between 95a and 225amps. So you want the least resistance possible.
            • Peter A
              • Sep 2012
              • 1486
              If you want to check the amp draw etc then it would be best to purchase an esc with data logging.
