Yeah, I think so. Start with a small prop and check temps. Or use a data logger... I only data log. But temps should be enough. Looking for motor temps around 140-150, ESC temps around 130-140.. if an ESC comes up for sale cheap in the 220-250a range, might want to shag it. So you race gas? Do you have a nitro boat? I started in nitro hydros, a long time ago... I'm loving FE, being an electrical engineer. LiPo batteries make a big difference, but miss the run times and noise of nitro sometimes!
TP Motor Kv unknown
Here's a fairly simple/accurate way to find out KV on a motor already installed in boat. (Can rig a motor-only bench tester if need be):
Step One : Get your hands on one of these *
Step Two ::
Plug everything in on boat and arm
On propshaft install a spare servo arm (or whatever) with supplied reflective tape stuck on for reading.
Install a volt reading device on the battery.
Step Three :
Aim tach at reflecto-thingie with one hand and push button
Pin xmitter WFO with other hand
Take picture for thread with third hand (
Battery V reading at WFO ; (battery started at storage V but doesn't matter for this test)
RPM reading at WFO :
Step Four :
Divide RPM 31,500 by WFO V 14.67 - you get a bench calculated KV of 2161.97 . Stated KV from TP Power is 2200. Pretty slick
*Tach won't break the Bank :
'11 NAMBA [P-Ltd] : Mono, Offshore, OPC, Sport Hydro; '06 LSO, '12,'13,'14 P Ltd Cat /MonoComment
Thanks chopper, and everyone else for the info. After I get this busted hull figured out I'll revisit the kv issue. I know I can just run a couple different S batteries, but if it works good I'm going to want to know what I have.IMPBA 20583Comment
