TP Motor Kv unknown
  • Insanity Plea
    • May 2017
    • 562
    TP Motor Kv unknown
    I received a TP 4060 V1 motor as part of a package deal, it was assumed to be a 2040kv but I don't see that as a listed kv. The numbers are not on the silver label like normal. Any way to tell the kv?
    IMPBA 20583
    • 7651
    KV checker is about it. No #'S whatsoever?
    • Insanity Plea
      • May 2017
      • 562
      None at all.
      IMPBA 20583
        • 7651
        Well, could toss it into something and see how it goes. One would assume 4s if it is 2040kv.
        • Insanity Plea
          • May 2017
          • 562
          Do you have a suggestion for which kv checker to use? I'm not sure if the one hobbyking sells will work on a 4 pole. TP list a 1950kv & 2310kv so I'm doubting its a 2040kv.
          IMPBA 20583
          • Prodrvr
            • Jul 2015
            • 701
            Just watched a video on this the other day. See if I can find it.
            • Prodrvr
              • Jul 2015
              • 701
              This one might work for you: http://www.ebay.com/itm/SKYRC-BMA-01...25.m3641.l6368
              • Insanity Plea
                • May 2017
                • 562
                Originally posted by Prodrvr
                It might, but for an extra $40 I could buy another TP. I'll try it on 4s and then 5s to get an idea of what it might be.
                IMPBA 20583
                  • 7651
                  I have the hobbyking one tho I haven't put it to use yet. TP changed things awhile back and the kv's did too. Any chance of a pic of it?
                  If it is 1900kv it will be a bit of a dog on 4s whereas if 2300 it will be hot.
                  • Insanity Plea
                    • May 2017
                    • 562
                    IMPBA 20583
                    • Insanity Plea
                      • May 2017
                      • 562
                      At this point, the motor is the least of my concern. I just discovered the boat that the motor was sent with has the gel coat spider cracking on the bottom of the sponson, at the rear on the ride pad. Wasn't planning on blueprinting until I was ready to fine tune but I guess it'll be the first thing I do now ...
                      IMPBA 20583
                      • CraigP
                        • May 2017
                        • 1464
                        Ouch! Looks like an impact crack. That's a lot of work redoing that so you have a foundation to blueprint. Would love to see pics of the work along the way!
                        • Insanity Plea
                          • May 2017
                          • 562
                          I'm tempted to grab the aeromarine avenger 36. Those hulls are laid up heavy but that comes with dealing with over 2lbs more than the cheetah. Think the boat is too heavy for a single TP4060 1750kv on 5s? That's the set up I have for the cheetah.
                          IMPBA 20583
                          • CraigP
                            • May 2017
                            • 1464
                            I think that motor will push it. May have to up your ESC. I was going to recommend just getting another hull, but didn't want to rain on the parade. That's what I would do... just estimating, but about 220a might be what to expect. Of course, if your racing, then I really don't know..
                            • Insanity Plea
                              • May 2017
                              • 562
                              Not racing FE, just gas. I have a couple v2 seaking 180s so I wanted to run one and have the other as a backup. Think I'll be pushing it?
                              IMPBA 20583
