were can i get this motor if exsist
  • langevn
    • Mar 2015
    • 214
    hi i was told there is a chinese made rc boat motor size 3963 2200kv does it exsist or not >?? anyone know were to get it if exsist
  • revoltrunner
    • May 2014
    • 646
    here's a 3974 2200kv
    http://hobbyking.com/hobbyking/store...ess_Motor.html
    • Luck as a Constant
      Make Total Destroy
      • Mar 2014
      • 1952
      Buy a leopard 4074 2200kv here on OSE
      • langevn
        • Mar 2015
        • 214
        i would like to stay with the same mount from my leopard 3674 2200kv as much possible
        • ray schrauwen
          • 9438
          The 3963 is most likely a HET or a Tenshock 4 or 6 pole motor.
          Nortavlag Bulc
          • ray schrauwen
            • 9438
            The Leopard 3674 2200kv is a very nice motor, why change it?
            Nortavlag Bulc
            • langevn
              • Mar 2015
              • 214
              i find not fast anought for my boat
              • Meniscus
                Refuse the box exists!
                • Jul 2008
                • 3222
                Maybe I'm confused when reading this. You want to swap motors for the same kv?
                Have you considered selling your current motor and purchasing one with more kv? Also, if the boat is not fast enough for you, you might look at a prop change. There are many knowledgeable users on this forum that can make recommendations for an alternate prop if you can share what you have tried and what the results have been. In many cases, you may see less current and longer runtime as-well-as provide more headroom to allow for larger props or props with a different pitch profile to accomplish your goals.
                • langevn
                  • Mar 2015
                  • 214
                  i have try x442 and after 6 lap my batteries were swall up and i have also try x445 and the same but everything was running hot like average 115 to 120 degree?? battery swall up again
                  • 785boats
                    Wet Track Racing
                    • Nov 2008
                    • 3169
                    Looks like you need better batteries. Those temps aren't overly hot. But if your batteries are swelling at those temps then I'm afraid they are just not up to the task.
                    What size in mah & C rating are they?
                    • langevn
                      • Mar 2015
                      • 214
                      the batteries are zippy lipo 5000mah 45c 7.42s and now i will be using aga power 6200mah 50c 7.4v 2s and iam using a x442 prop
                      setting hobbywing esc is 3.75
                      • domwilson
                        Moderator
                        • 4405
                        I would try strut adjustments and battery placement first. You might get more speed and runtime. Plus it's free.
                        Government Moto:
                        • oscarel
                          • Dec 2009
                          • 2135
                          http://forums.offshoreelectrics.com/...-hot-and-swell
                          Again, you probably don't have enough capacity for 6 laps. Also, going to a bigger prop isn't going to reduce the swelling. How much did you put back into battery after your run??? 6200mah still may not be enough.
                            Make Total Destroy
                            • Mar 2014
                            • 1952
                            Going to a bigger motor will just make it worse.
                            He just wants someone to give him the magical answer.
                            • langevn
                              • Mar 2015
                              • 214
                              iam looking for answerd of why my batteries swall up and i saw a nother boat using these batteri with the same setup and is didnt do like mine that was confuse me but the problem is only one battery is swellingup the other one is ok and by the way iam usin 2 bat 2s 7.4v of 5000mah 45c for lopard 3674 with 120 esc and prop octura x442 3/16 flex shaft and the boat is miss duce vegas converted to electric
