need motor and ESC help please
  • hydro rookie
    • Feb 2015
    • 10
    I need help to find an equivalent motor to TorQstar2 7040/6 outrunner with 14s lipo and MGM TMM 40063-3 X-2 series ESC. This set up is quite expensive and I would like to find something a bit more buget friendly. I dont know what other options are available. Any assistance would be greatly appreciated. Thanks for your time !!
  • Doby
    KANADA RULES!
    • 7280
    What do you want to use it for?
    Grand River Marine Modellers
    • hydro rookie
      • Feb 2015
      • 10
      Sorry guess that would have been useful... Its a hydroplane boat. thanks for your response!!
      • Doby
        KANADA RULES!
        • 7280
        What size?
        • hydro rookie
          • Feb 2015
          • 10
          Its about 90" long and about 40" wide. The motor/ esc set up I mentioned earlier was from the folks at lehner motors. I just am assuming that there are comparable set ups for a few less dollars. something I can get in the USA as well.Thanks again
          • egneg
            • 4670
            Neu 2230 1Y, swordfish 300 pro+, 12S2P ... motor - 850.00, esc - 300.00, lipos - 500.00 to 600.00.
            IMPBA 20481S D-12
            • Doby
              KANADA RULES!
              • 7280
              Holy crap that's big!
              • egneg
                • 4670
                MGM has a 400 amp esc for just under 900.00
                IMPBA 20481S D-12
                • Doby
                  KANADA RULES!
                  • 7280
                  That size of a boat and "budget friendly" rarely go together.
                  What "budget" did you have in mind?
                  • hydro rookie
                    • Feb 2015
                    • 10
                    Thanks for all the feedback from everyone!! I appreciate all the expert info/advice
                    • hydro rookie
                      • Feb 2015
                      • 10
                      Good point and you are very right nothing has been very budget friendly so far but It never hurts to try.
                      • egneg
                        • 4670
                        You might be able to get the motor used for a couple of hundred less but I would not trust a used esc or lipos.
                        IMPBA 20481S D-12
                          Yes, budget is relative. A close equivalent outrunner to the Lehner is the Scorpion 7050/340 Kv motor. High quality, high power, about 30-40 percent less costly. But the big Neu 2230/1Y referenced above is a decent choice for less $$$. I do not know why people will recommend a 300 plus ESC for a high voltage boat, it just is NOT needed! The power comes from the voltage, not the amperage. With 14S a 250-300 amp controller is plenty. That's 13,000/15,000 watts, more than enough.
                          • hydro rookie
                            • Feb 2015
                            • 10
                            Thank you for the additional suggestions. Its really great that people are so helpful on this forum!!!
                            • Make-a-Wake
                              FE Rules!
                              • 5557
                              Too bad this hog doesn't have a bit higher kv.......................its bigger than the Torqstar
                              http://www.hobbyking.com/hobbyking/s...ner_Motor.html
