Not sure yet, thinking a 450, I just picked the hull up and should have her together this week. Just finished my single cheetah with same power
Pursuit mono motor and prop advice
https://www.facebook.com/groups/EliteRCBoats/ -
I run the x548 I suggested on my 39" mono, Castle 1717 (1580kv) on 6s2p and get 60 out of it..................great prop, you dont want too much diameter...........an x450 should do well too thoughNEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
In my pursuit, I have a leopard 4082 2000kV and swordfish 130A HV ESC. I run it with a 5000mah nanotech turnigy 5S batt. I don't remember exact specs on the prop as I just went to the local hobby shop, told him the specs and asked what he suggested. I'm pretty sure its 45mm dia. I haven't upgraded the cooling in it so I keep an eye on the temps wen I run it but so far I have not had any temperature issues. I bought a swordfish 180A esc which I was planning on running with 6S but I think the esc is a dud. It does not run fast at all and does not accelerate anymore past 1/4 throttle. Yanked it back out and gone back to the 5S setup. The 6S battery and that motor would kill the 130A esc I think. Most people I tell scratch their heads but it works for me. I'm yet to get a GPS readout from it but I would estimate that it would be pushing 100kph when I can keep it in the water.Comment
Question about the same hull, in the build process on mine and was wondering if the kintec replacement cf turn fins off a sv27 would be long enough for this hullHPR 135 redemption, HPR C5009, modded zelos 36, 32 boats and counting.
https://www.facebook.com/groups/EliteRCBoats/Comment
I think those turn fins would work, the Pursuit can actually corner very well without fins, although in sanctioned races you would want the benefit of turn fins obviously.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
Ok. I have decided on a Leopard 4082 and a Swordfish 220 pro. (Or should I get the SeaKing 180. They are both the same price in UK) I will be running 4s2p but now looking at props? I did run an M445 on the original motor.. soooo can I still use this prop, or should I be trying an X440/445? ThanksComment
What kv???NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
Beefy motor, great choice, my prop suggestions for 4s2p:
x548, x645, y547NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
I went through a the X6 props on my 35" DF too with all kinds of hopping and submarine instances. Don't get me wrong, it flew with them but very loosely(POOR HULL).Comment
The x645 would actually be my 3rd choice of the three i suggested, x548 first(great prop) and the y547 second.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
Would someone be able to tell if this esc auto detects the amount of cells. It came with no instructions and I want to be sure before I take it for its maiden voyage. Thanks. DaveAttached FilesComment
