What do you use to cut flex cable?
  • HangTheMan
    • Sep 2014
    • 74
    I recently purchased single piece flex cables to replace the two piece flex cables in the Genesis, Smash Shark and Pursuit. I have to cut the cable down to size. Curious as to what tool to use to cut the flex cable. Would a regular hack saw do the job or is there a special tool to not damage the flex wires? Also are there any tips or tricks to cutting the cable?
    Any help is greatly appreciated.
    Thank you,
    Dillin
  • fusion_m8
    • Jan 2013
    • 53
    I used a dremel with a rotary cutter. Make sure you get a good quality rotary cutter made from quality high speed steel. If not it won't do the job properly and safely.
    • electric
      • May 2008
      • 1744
      Ditto. Dremel cutting disk and lot's of sparks and you are done...
      • longballlumber
        • 3119
        Like the other suggested a dremel tool with the following attachment does a nice job.
        Later,
        Mike
        • larryrose11
          • Jun 2010
          • 761
          Angle grinder baby!!!
          • fusion_m8
            • Jan 2013
            • 53
            C4!
            • BHChieftain
              Fast Electric Addict
              • 1964
              After you cut the cable soak and scrub the end with acetone and flow some solder at the cut end to keep it from unraveling
              Chief
              • BrianW
                Rocket City Racing
                • Aug 2011
                • 90
                If you do a few, I use this. http://www.harborfreight.com/6-in-55...saw-61204.html
                • siberianhusky
                  • Dec 2009
                  • 2184
                  LOL C4! I use a dremel then hit the cut tip with my mig welder, quick spin on the bench grinder and good to go.
                  A torch and silver solder works fine on the tip, but my welder is just so much quicker and more handy. Tip done in about 2 seconds and don't have to worry about changing the temper of the cable where it matters.
                  • olwarbirds
                    Magic Smoke Wizard
                    • Oct 2012
                    • 1136
                    Originally posted by fusion_m8
                    C4!
                    I almost spit coffee all over my keyboard...If you don't have a dremel, its time to buy one or something similar. Safety Glasses ! like already suggested clean it good, acetone is what I use, then you can melt some solder in a shell casing or crucible, dip tip in flux, dip in solder, wipe with rag, repeat. once done just use some sandpaper or light grinding to clean it up...DJ
                    • T.S.Davis
                      • 6228
                      I like to use a beaver..........then clean it up with a dremel.
                      Noisy person
                      • HangTheMan
                        • Sep 2014
                        • 74
                        Thanks everyone for the tip! Really appreciate it. I had tried previous to cut one with a pair of wire cutters, that of course didn't turn out too well as you can imagine. Gonna do it right this time around. :)
                        Dillin
                        • flraptor07
                          • Aug 2013
                          • 2451
                          That mig welder tip is killer I'm gonna have to steal that one!
                          • gsbuickman
                            • Jul 2011
                            • 1292
                            Ha ha, I nearly lost my coffee all over my new smartphone when I read that too, because I was in mid drink when I saw that, Damn that's funny ....
                            I use a 4.5" angle grinder with a hot saw cutting disk on it, they slice through metal like a hot knife through butter
                            • gsbuickman
                              • Jul 2011
                              • 1292
                              If you try a snapping turtle be damn sure where your fingertips are first.
