Just gives him more head room with 4s-8s
Thoughts on Castle 1717?
The Hifei Swordfish Pro Plus 220 2s-6s has a BEC, data logging.
http://www.offshoreelectrics.com/pro...d=hef-HB61220L
Or was there a reason you were going for the 200A 4s-8s?
More flexibility for future use. Plus being fully sealed in an aluminium case, they look soo much nicer.Last edited by rickwess; 10-29-2013, 08:53 AM.Comment
That 1717 can pull a lot of amps. If you can swing a castle 240 I'd do it. If not go with the sf 220/300 6s ESC I think its been doing better than the 8s 200. The 1717 is a 1600kv motor but its a big can and can spike with a lot of amps.Comment
I've run the 1580 version and it can pull lots of amps. Even ran one as an outboard.
IMG_0716.jpgLast edited by oscarel; 11-05-2013, 10:20 PM.Comment
There were 4 versions of the green 1717......2 air versions 1580 + 1500 with open endbells (both 6mm shafts) and 2 car versions both 1580kv but 1 with a 6mm and 1 with a 5 mm shafts
1717 007.jpgWhen you know it all.......you never will learn anything newComment
