I just bought 1717 here used so he said 3 times but the bolts are rusted and and there is end play aboutless than 1/8th inch how do i fix that.im trying to get ahold of the guy with no luck yet i may go to paypal and request a refund not as described
1717 castle
Did you bench test it yet to see how it sounds ?
The end play does not sound to far out for a used motor,
I think he run in salt water to, But not sure on that. -
That much end play probably means the motor has been opened. If so, when it was put back together a spacer may have been left out. You may want to send it back to Castle for a once over.
Send in the one you just got ( used with play) with the receipt from your NIB. Castle fixes problem solvedComment
Or, if the bearings are fine laterally, just put a thrust bearing on it when you mount it in the boat to stop the endplay.See the danger. THEN DO IT ANYWAY!!!
I use clutch bell shims(for nitro cars) to take out some of the play in my motors when I rebuild them.My private off road rc track
https://www.youtube.com/watch?v=XC3H...yaNZNA&index=8Comment
not good man, sorry to hear of these troubles specially from our swap shop.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
SirBudman32 told me when he rebuilt his 1515 it only came with two shims- one for each side. When I opened up a Leopard motor there were numerous shims on each side- it was custom fitted to be more precise.
What Im getting at is the Castle motors might just have more slop to them right from the factory. You could possibly measure the difference and cut your own brass tube shim to fit if you really wanted to.42" Osprey, 32" Pursuit, 26" Bling Rocket (rescue), Blizzard Rigger, JAE 21FE rigger, Hobby King rigger (RIP)Comment
My 1717 came with quite a bit of end play new. About a .100". The assemblers in China are not always careful with the amount of shims that put add to the rotor on either side. Actually it is not such a bad thing as preplay on either end allows the rotor to center magnetically. So use a thrust washer and set the clearnance for several thou and you will be just fine.
As for the rust on the bolts. It only takes one trip with moisture to cause the cheaply plated bolts to rust. Use a little WD40 to coat them and they will be fine.
TGTyler Garrard
NAMBA 639/IMPBA 20525
? ONLY IF THEY WORK
