1717 castle
  • nitronuts
    • Feb 2012
    • 942
    1717 castle
    I just bought 1717 here used so he said 3 times but the bolts are rusted and and there is end play aboutless than 1/8th inch how do i fix that.im trying to get ahold of the guy with no luck yet i may go to paypal and request a refund not as described
  • lenny
    • Sep 2010
    • 4294
    Did you bench test it yet to see how it sounds ?
    The end play does not sound to far out for a used motor,
    I think he run in salt water to, But not sure on that.
    ? ONLY IF THEY WORK
    • nitronuts
      • Feb 2012
      • 942
      it runs fine but for 3 uses it should have no play at all
        That much end play probably means the motor has been opened. If so, when it was put back together a spacer may have been left out. You may want to send it back to Castle for a once over.
        • nitronuts
          • Feb 2012
          • 942
          point is used 3 times so i bought it and its well used i would rather send it back just bought for a spare i have a new in box one
          • Heaving Earth
            Banned
            • Jun 2012
            • 1877
            Usually after a few runs of my motors they get a tiny amount of play. Maybe 1/16 at most
            • nitronuts
              • Feb 2012
              • 942
              Ok thanks
              • jkr
                FE Addiction
                • 568
                Mine had litle play from the box.
                Is was with 6mm shaft.
                • TheShaughnessy
                  • 1431
                  Send in the one you just got ( used with play) with the receipt from your NIB. Castle fixes problem solved
                  • 785boats
                    Wet Track Racing
                    • Nov 2008
                    • 3169
                    Or, if the bearings are fine laterally, just put a thrust bearing on it when you mount it in the boat to stop the endplay.
                    • nitronuts
                      • Feb 2012
                      • 942
                      I will use a thrust bearing.thanks for all your input
                      • kevinpratt823
                        • Aug 2012
                        • 1361
                        I use clutch bell shims(for nitro cars) to take out some of the play in my motors when I rebuild them.
                        My private off road rc track
                        https://www.youtube.com/watch?v=XC3H...yaNZNA&index=8
                          • 9488
                          not good man, sorry to hear of these troubles specially from our swap shop
                          • Basstronics
                            • Jun 2008
                            • 2345
                            SirBudman32 told me when he rebuilt his 1515 it only came with two shims- one for each side. When I opened up a Leopard motor there were numerous shims on each side- it was custom fitted to be more precise.
                            What Im getting at is the Castle motors might just have more slop to them right from the factory. You could possibly measure the difference and cut your own brass tube shim to fit if you really wanted to.
                            • RaceMechaniX
                              • Sep 2007
                              • 2821
                              My 1717 came with quite a bit of end play new. About a .100". The assemblers in China are not always careful with the amount of shims that put add to the rotor on either side. Actually it is not such a bad thing as preplay on either end allows the rotor to center magnetically. So use a thrust washer and set the clearnance for several thou and you will be just fine.
                              As for the rust on the bolts. It only takes one trip with moisture to cause the cheaply plated bolts to rust. Use a little WD40 to coat them and they will be fine.
                              TG
                              Tyler Garrard
                              NAMBA 639/IMPBA 20525
                              T-Hydro @ 142.94mph former WR
