I would say since your running a 54" hull and you have the space for batteries. I would run a comparable size to a 40mm or a 56mm at what voltage you wanna run. Do you wanna run 1p or 2p?
Which motor is better?
I vote for two SSS 5684 1000kV or two TPPower 4060 (40x92) 6Y 980kV. And if you want long run time use 3 x 10S wired in parallel for the 2 combosComment
I'm going to run 8,9 and 10s2p in my mono. With twin 528's. With the right props on 10s you could hit 80mph. I think I'll just prop my mono to top out at 70mph. After I get done with it and the paint job is done. I'll be afraid of crashing itComment
What do you guys think of the Leopard 56-110 780 Kv motors on 10s ?
How many watts are they rated ?
don't mean to hi-jack this thread............
Thanks,
Harry60" Expresscraft SuperCat
(2) 2028 Castle motors 64.7 mph
10s3p with x450/3 props 15,000 mah 40c cells,Comment
56 size Leopard motors on 10s:
From what I read in other threads is that the Leo's are getting hot and the quality is not that high as the TP power motors. read the new PROTUES motors are a beast so I think I am gonna order a pair of X524 910KV motors and run them on 8s packs. Good choice Keith?Comment
There are a million ways to go with a hull this size, but that should work for sure...what are you trying to do with it? Go carzy fast, or just a "sport" type setup?Comment
No I don't want to burn out the motors. The Protues 910KV motors are rated 33volt max although the leopard 5692/1090 are rated the same and the guy i movie I placed in this thread is using 10s.Comment
If you want to go over 100, you might want a more RPM capable motor, like a Lehner or Neu.Comment
