gfm i just looked these up and they do have a program card and it looks identical to a hobbywing or turnigy and the card looks the same also if you can find someone that has one near you i bet there card would work for you esc
Motor has no power when in water
lvc is separate from cell count. Cell count options will be like. auto calculate, 2 cells, 3 cells, 4 cells, etc. LVC options will be like no protection. 2.8v, 3.0 v, 3.2v, 3.4 v or might just be none, low, med, high
Also that motor is almost better suited for 2s. what kind of boat is this in? might be ok in a rigger.
How old is the battery? I know its rated for 200 amp constant but that doesn't necessarily mean that it can put out that much. It may be sagging under load
What prop are you spinning? 3400x11.1= 37740 so pretty high rpm for sport usage.Comment
is this your esc? looks like there isn't a LVC and it is set automatically based on the number of cells. You could try setting the cell count to 2 s to trick your esc, but then you would have to be very careful to not run your battery down too far. Its pretty much your only other option though.Comment
